Also did ye not see the photo on pg 2 of this post? Cheers
jkjenn said:One thing I noticed that therenis more wood in the 2021, including this around the doot.
That is actually in the 2020s too. Its to accommodate the new door, with a place to mount the screen.
When hubby and I are camping together, we DO have to empty the portable toilet every morning. The portable toilet has a 5 gallon capacity. Age and medical conditions create a lot of overnight liquid for us. So, I believe that we would have to empty a cassette or dump an 8 gallon tank with the same frequency. (As a matter of fact, with a regular holding tank, I think we might actually use the toilet more during the day instead of walking down to the comfort station.)Marceline said:First, I think that you’re overestimating how frequently the cassette will need to be dumped.Mouseketab said:Here are the steps with a cassette in a FHU campsite on a daily basis, because with two people overnight needs only that thing will be full. (Two - Three uses per person each night)
<cut>
The steps for an 8 gallon blackwater tank on a daily basis with hoses already connected
<cut>
Second, I think that you should recognize that most T@Bbers aren’t camping at full hookup sites. Only 4 of the 42 people who responded to my survey are camping mostly at FHU sites. It’s great that you enjoy your trailer this way but it’s not really how most people use their T@Bs.
For those who camp at places where there’s no sewer hookup or maybe even no dump station (most T@Bbers), the cassette will provide more options for getting rid of black waste. For an extended stay (4+ days), currently the only options are to drag around a blue boy or break camp and go to a dump station. Neither option is particularly appealing.So although this change might not suit some people, I would hope that people could understand the reasoning behind it.
I think you can get a spare tire mounting bracket for the small platform in front of the tub.Cherokee said:The new spare tire location below the trailer frame I saw in another video by Princes Craft is a disaster for ground clearance. As someone that takes his modified 2019 320 Boondock on dirt trails, I wouldn't recommend this one.
I’m pretty sure that I read somewhere that the cassette uses less water per flush. If that’s true there might not be much of a capacity difference.Denny16 said:Cherokee, the difference between the original black tank and cassette is only 2 gallons. You can fill the cassette up to max capacity, doubt I would do that to a small black tank mounted directly under the toilet.
jkjenn said:I think you can get a spare tire mounting bracket for the small platform in front of the tub.Cherokee said:The new spare tire location below the trailer frame I saw in another video by Princes Craft is a disaster for ground clearance. As someone that takes his modified 2019 320 Boondock on dirt trails, I wouldn't recommend this one.
Coming up from the bottom would solve the door problem. But that would take a lot more effort then it takes now with the connections on the side of the trailer. I don't know about you, but I'm often tired by the time we stop and the additional effort to connect is not something I'd be happy to do. And opening a valve is MUCH easier then carrying the waste, but perhaps owning one of the older one's has made me lazy. Still, I'd gladly change this option for the old exterior access to storage which made access to wheel chucks etc... a breeze.Denny16 said:Cherokee, the difference between the original black tank and cassette is only 2 gallons. You can fill the cassette up to max capacity, doubt I would do that to a small black tank mounted directly under the toilet.
If the T@B you have gets totaled or stolen, then few options to get a replacement that you love.Marceline said:If you already own a T@B then how does this affect you?lino said:Unfortunately this means the end for me for Nucamp
At least until I am ready for a camper with no bathroom
Put a right angle adapter + quick connect on the water port. Easy peasy.Cherokee said:On a cold day, reaching under the trailer, feeding the hose up then bending that stiff hose 90 degrees will not be welcome task either. It rains in my world.
jkjenn said:A couple of other small things I noticed on the new T@b.
The first I thought about after I got home. I went to PJ's video and looked at the cani ets. Look how little space the plumbing under the sink takes up. It appears they may have used the HEPVO valve. This is not something you would due to cut corners and cost.
The second thing is the high quality latches in the rear overhead cabi ets. They are really robust.
Marceline said:Put a right angle adapter + quick connect on the water port. Easy peasy.Cherokee said:On a cold day, reaching under the trailer, feeding the hose up then bending that stiff hose 90 degrees will not be welcome task either. It rains in my world.
I think part of what nuCamp is up against is that when it comes to spending large chunks of cash, customers want options. Meanwhile, companies want to streamline production, and the easiest way to do that is to limit the customer’s choices. Too many options will slow down production, and affect their bottom line. (I rail against Apple on this all the time, I promise I’m not just picking on tiny nuCamp!)ontheroad said:@Cherokee ...I think nuCamp does a pretty good job of figuring a lot of things out...and they do listen to their customers (us)...but there is not "one size fits all" when it comes to how we all use our trailers...Marceline's poll proved that...
I've been looking at the photo of the CS interior and I think there's an easy change to make it work for the popular full-time twin bed setup.ontheroad said:@Marceline , when Frank and I saw the prototype of the CS-S while we were visiting nuCamp that was the first thing I mentioned to Scott...you need to keep the split cushions for those solo traveller...he and Rapheal had never thought how you solo travellers use it.. it raised an issue that they had never thought about...
Yes, I thought about it, but I think that AC unit is fairly deep - maybe 18" or so. So you might need only another 12" to get to twin bed width. I'm pretty sure the pullout rails have supports, so I'm not sure that splitting them and adding an extra set of supports would be worth it for the company. I think that a board is a cheaper and easier solution for the twin setup. But I could be wrong.Sharon_is_SAM said:That would work @Marceline. It would be nice if they could split the pull out rails, so only a portion met in the middle allowing a solo CSS owner to have the single bed set up and sleep wheel to wheel. No extra board needed.
https://youtu.be/YMEP7B3VX002021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
