We got the call today that our TT has arrived. It's 219" long and weighs 2864 lbs. We've named it Lil' Joe. It's new best friend and TV is a Toyota Tundra we call Hoss. We hope to pick it up this weekend. Pictures to come.
2021 T@B 400 BDL aka Little Joe
2019 Tundra Crewmax aka Hoss
SE Louisiana
4 ·
Please do post lots of pics when you get it!
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
looking forward to your pics!
It does have a coolcat
The water management system's not too complicated.
Some other I believe differences with previous models. Table is lighter.
Wardrobe is different I believe.
Pushbutton ignitor stove
12v low draw fridge
Raised the back window I think
And I think the shower assembly has changed.
It also has a gas outlet at the rear of the 400. There is no rear camera. The step is different too from what I remember.
SE Louisiana
Jeff & Amy
SE Louisiana
@cottonmouth, can you link the new user manual? I would like to know more about the water management system on the 2021s.
The open cubby under the wardrobe is a nice change. In our 2020, there is a lot of wasted, open space in there that isn’t usable. Where did they put the water pump then?
A few of the incremental updates such as gas outlet, square sink, etc. Are things I am considering doing to my 2019, should be easy. Other things like the natulis water management system would be very difficult.
This new design uses the same cabinet fronts as the new larger 3-way fridge, so the fridge area becomes the hanging locker (closet). This new front unit is now separated from the head/wet bath and set back some to create more space next to the rear bunk/bed area. Remove the rear bunk, and new closet/fridge unit ( now a separate bit) and you add the Solo model bunk over the Alde area running from head/bath wall to trailer back.
Both now have the same head/bath module. A modular layout like this reduces construction costs and different models now share the same bits. Seems like a good move to me.
1: What's on the bed side of the new wardrobe configuration? Any new/larger cubbies?
2: Is the fridge door stainless or black?
thanks & congrats again!
There's a cubby about 12''x18'' on the bedside of the wardrobe.
On top is a light switch, middle is the on/off switch for AIMS 1200w pure sine inverter, and on bottom is a plug with usb
The light switch turns on accent lights above the bed
There also a small puddle light above the step that comes on when it's pulled out (my flash is making it brighter than it is. It's just a little blue light pointing down)
Finally, here's a look inside the tub. The sewer holder is gone in back, but it would fit very easily behind the propane tank in the separate chamber there
SE Louisiana
SE Louisiana
Kind of frosts me that NuCamp decided we no longer need a DVD player.... Now, in order to watch our favorite old movies we have to rig up and power another device. With the head unit where it is located now makes it even more challenging. Not all of us have Netflix, fancy phones, or hard drives full of movies....! Jensen makes a very similar unit with a DVD that costs a little more.... For $30k+ I wish they were a little less penny conscious....
Jim
I’ll wait until Friday—thunderstorms forecasted for this afternoon😉
SE Louisiana
SE Louisiana
SE Louisiana
Nissan Frontier PRO-4X (4.6 liter automatic)
Roof mounted solar panels
