I cant make my mind up, i currently have a tag xl, buying either a new 320 or 400, when this is all over. Im 6 foot 3
We are still working so only would be weekend trips, 5 months or the year
What would you do?
2021 T@b 320 Boondock | 2021 T@b Nights: 40 | 2019 Honda Ridgeline | NuCamp owner since 2017
0 ·
At 6’3”, you’re potentially going to be very annoyed by the low roof in the 320, and unable to fully stretch out on the bed. At 5’6”, it’s fine for me, but taller friends who’ve spent even 15-20 minutes in there have said flat out it wouldn’t work for them, even those who otherwise love the features. For some people, it just isn’t a good fit; for others, the compromises are worth it. Only you can decide what you’re willing to put up with.
Edit: And since we’re taking the 2021 models, the 320 has a cassette toilet, while the 400 has a more typical black tank. For some folks, this is no problem, for others, either option could be a dealbreaker. Worth doing the research to know how you feel about that issue.
I wont be showering in the 320 i will have to sit to pee!
My tow vehicle is a 2017 honda ridgeline
The 320 is so easy to fit in really small sites. The 400 isn't that much bigger, but there are some sites you might not be able to take with a 400 that you can with a 320.
If at all possible, spend some time sitting and walking in both. Your height is probably less of an issue than your tolerance for small spaces. If you have been OK in a T@g, my guess is that you will be OK in a 320. If you would like to spend a lot more time inside of the trailer, a 400 might be a better option. If you anticipate still mostly sleeping inside and still spending most of the time outside, the 320 will probably be just fine for you.
Lastly, you will get more storage with a 400, but most of us make do with what we get in the 320 and appreciate the help keeping us packing light.
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Is your 2017 Honda Ridgeline a 2WD or All 0/4WD drive model? 2WD 3500 lbs max tow.
TaB 400 is at GVW 3500 lbs and around 2800 lbs dry, with a 400-450 lbs tongue weight, which will subtract from the trucks max load.
Does you Honda have a 4-Pin or 7-Pin with 12 VDC circuit?
A TaB 400 needs the 7-pin and you need a brake controller, not an option, somifmyiumhave factory tow package you should be set here.
The closer you max out your TV, the less enjoyable towing a bigger trailer like the TaB 400 is.
we have the closet Model, and love the extra room. I reversed the shower door, so the head could be accessible more easily from the bed area, especially at night when you have to go... ugh!
Concord, NC
I agree with @Dutch061 about tow vehicles, seriously considering a Tundra instead of the 4runner. On paper the 4runner is more than enough but seems to fall short in power and rear visibility with the width of a 400.
In comparison, most of the 1/2 ton pickups from Ford, Chevy and Dodge have estimtes closer to 22 - 23 on the highway. Engine choice, 2WD/4WD, etc. will influence that a little. Either way, towing a 400 is going to cut that mileage in half per what most owners report, myself included.
If you are not in a position either by circumstance or by choice to change tow vehicles, you will have to live with its limiations and make decisions about your trailer based on those restrictions (as we all do). I know you're aware of that and is likely what likely prompted your original question.
It still primarily comes down to math, and there are certain fixed limits that simply cannot be safely exceeded. If you're under those limits with your tow vehicle and trailer combination, it then comes down to what you're comfortable with in terms of margins, how light you're willing travel in terms of extra cargo, and the terrain you plan to traverse. Towing through the midwest or northeast is a way different from towing at high altitudes on mountain roads.
Components like weight distribution and anti-sway hitches are specifically designed to help with control - within the bounds of the specified limits - and to help prevent things from getting out of hand in situations like high winds, the need to stop or change lanes suddently, or even to mitiage the push induced by an oncoming passing semi.
The braking ability of the tow vehicle isn't really a factor if the trailer has brakes. When the brake controller is properly set up and adjusted, towing a trailer should not put any additional strain on your vehicle's brakes.
I'm curious about the comments concerning the relationship between tow vehicle and trailer widths and weights.
Some smaller trailers may be narrower than the vehicle towing them, but it's more common for the trailer to be wider. That's why many pickups come with extendable tow mirrors - they're expecting the trailer to be wider.
As far as weight goes, trailers that outweigh their tow vehicles is not uncommon. Using a Chevy Silverado as an example, their 3/4 ton models weigh between 6,000 and 6,700 pounds and are rated to tow as much as 18,000 pounds with the proper configuration. A 1 ton version weighs between 6,000 and 8,000 pounds and when properly configured can tow up to 35,000 pounds. Fifth wheels and big toy haulers routinely weight 10,000 pounds or more, but even 1 ton trucks do not.
Same applies, towing a trailer that is significantly wider than your TV requires special considerations, slower speeds and careful cornering, as well as the extended mirrors. My point was, the closer your trailer is matched to the TV, will result in a better towing experience with more positive control over the trailer. I have pulled 8-9 foot wide trailers with 5-foot wide TV, and is not an experience I want to do very often. Pulling over sized rigs also requires much longer braking distances, and planning ahead when driving a setup like this.
Pulling a 7-foot wide TaB trailer with a 6-foot wide mid size truck is very doable and safe, and not much different than pulling a 6-foot wide trailer, except for cornering, one need ps to allow for the wider trailer axle. I saw a Jeep Gladiator PU truck pulling a 24-foot power fishing boat on a trailer that made the truck look very small by comparison of the load being towed. Not sure I would want to be driving that rig. 🙄
In the end , we decided on the 320s , for the larger bed size, and because of the smaller lighter tow factor . We now do not have to use our gas guzzling 1/2 ton truck, and have a dedicated tow vehicle for the 320 which works fantastic (2011 dodge Caravan 3.6) . Get about 16-18mpg towing with it. LOVE that the 320 tows SO well, without the use of sway bars or anything !
2001 Chevy Suburban LT 2500 8.1 - 496ci
2022 Jayco Jay Feather Micro 166 FBS
2021 Keystone Passport Superlight 229RK - SOLD
2019 NuCamp T@B 320s Grey / Black Trim. - SOLD
2011 Keystone Outback 260FL 32' - 2 Slides . - SOLD
