I went into our 400 today to start getting things ready for a trip this next week, and I was shocked to find water all over the dinette and the front cushions all soaked, water all over the floor!  After a little investigation, I figured out rain water pours in through the top of the window all along the aluminum window frame mount that attaches to the camper, dripping water into the camper.  I had left the front window open about 2 inches to keep it vented, and it rained overnight.  Apparently this is the first time I’ve had it open when it rained.
I couldn’t find anything in the manual about not opening windows when it rains.  Anyone else experienced this?  It would seem very odd to not be able to open a window when it rains.
                0 ·
If it was windy while raining, that could account for the water entering through the window. When it rains, and I am going to be away from the trailer, I only open the window to where it locks in the slightly open position. You can also crack open the roof vent to help with air circulation (or open it fully if you have an after-market vent opening cover.)
https://tab-rv.vanillacommunity.com/discussion/comment/117483#Comment_117483
As a side note, rain rarely comes straight down. It usually has some horizontal component to it.
Interesting. I wonder if nuCamp has changed that channel from what they used in 2019? The aluminum channel (or hinge) on mine is all one piece top to bottom and left to right with a sealant of some sort across the top of the channel and maybe behind it as well. I have not experienced any water leaks when I have had the window slightly open during a gentle rain. Have not tried it with a heavier rain.
You might query NuCamp about this.
Let us know if a bead of silicon seal fixes the problem.
BTW, is there not sealant of some sort along that aluminum channel now?
@Amazonics Feb 4th had a missing caulk issue on her 2020.
@falcon1970 you mentioned in an earlier post that with the window open the rain sheds over the “bump” and down the window. While applying “rain” with the garden hose, I have observed the water runs over the upper lip and down in behind the window; it does not shed over the outside of the window.
It appears that your "hinge/bracket" is different than mine for some reason. In your picture you show a flexible weatherstrip at the top of the window. And it appears as though it might be pulled out in the middle so it does not rest in the channel but rather outside of it. If so, then it Ian't keeping the water in the channel to run to one side but lets it flow into the open window. Mine does not have this flexible weatherstripping but instead has a hard piece of plastic that appears to be part of the molded window.
It looks like there are some other design differences also.
entry.
Chili, NY
The window T Slot is outside the trailer and drains out the ends. I would remove the window from the T Slot track, and check to screws to make sure they are sealed also.
I think nuCamp was advising caulking the top of the window track assembly, above the inside T Track. However, a proper repair, is to completely remove the top window track assembly, clean both the track and camper surface, and reinstall with the seal tape and caulk. Adding additional caulk outside the top of the track is just a bandaid, not a proper repair of the issue. I would be contacting your dealer and nuCamp Warranty to get this done correctly.
you say you did a temporary repair, and I’m wondering if you did a permanent repair at some point, and what did that entail? Hoping to avoid taking it to our RV place if I can fix it myself. Thanks!
St Catharines, ON
