I just bought a Toyota RAV4 Adventure. It has a hitch and a 7-pin adapter. I bought the wiring harness for a Toyota for my Tekonsha Prodigy that I used in my last tow vehicle. When I couldn't find the connector under the dash I brought it to a mechanic for them to do the wiring for the brake controller. They said they would have to rewire the whole 7-pin adapter since they don't know what the people who installed it wired it to. I called a Toyota dealer and they said it would cost $940 to install a brake controller.
Am I doing something wrong? I have the brake controller. I normally just plug it in under the dash. Am I using the wrong words? I don't need an actual brake controller installed I just need the wiring part to connect my external brake controller. Is there a better way to convey this to the mechanic? Does anyone have any idea what's going on and why this is so difficult?
Aileen, Muggles & Scout @ 2018 T@b CS-S @ 2018 RAV4 Adventure @ Massachusetts
0 ·
Your Adventure model came from factory with a Tow Prep Package not a Towing Package.
Tow Prep Package:
+ upgraded radiator,
+ additional engine oil cooler
+ transmission fluid cooler
Tow Prep Package does not Include the receiver or trailer wiring.
As far I can tell from web-research the RAV4 does not have the Trailer Brake Controller connector/harness you hoped to find. You need to direct wire into vehicle if you are going to use your older wired Brake Controller.
For the aftermarket 7-pin trailer connector suggest you confirm the wiring with extra focus on the +12VDC from battery . . . it may or may not be connected. With +12VDC at 7-pin then you should consider buying a newer Wireless Brake Controller and eliminate having to hard wire in your old controller.
Adventures: 53 Nights: 334 Towing Miles 42,600+
You still need a 10 g charge wire with a wireless controller.
Tampa FL
4 wires:
12v positive from battery, fused.
12v negative from battery post ground.
12v trigger lead.
12v wire from controller to trailer harness plug.
The trigger wire nowadays is the tricky part. One can't simply tap into the brake light switch willy-nilly. That switch is now a composite switch that controls all sorts of things like cruise control and ABS computer to name a couple. What I do is find the 3rd brake light wire on the rear hatch and run a tap from that to the controller. That way you'll avoid weird pulsing brakes, or no brakes, depending upon what turn signal or flasher is illuminated. The 3rd brake light is a straight-up, brake light without any frills. The brake controller needs only a tiny bit of power on the trigger wire so amperage isn't an issue. Some vehicles have a tap right in the fusebox that you can use but I just go with the 3rd brake light wire trick.
In the good old days, you'd just tap into the brake light switch for a brake signal, but those days are gone. To avoid dash warning lights, fried computers or an airbag in the face, just find and tap the 3rd brake light.
WilliamA
2017 T@G XL
Thanks for all the information and ideas!
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
It has a GVWR / GAWR of 2,900# and nearly all states require brakes over 2,000# GVWR
The 1,851# weight in the sales literature is an Empty Trailer; no food, no gear, no water, no etc..
Also, RAV4 is a small & light vehicle, a loaded 320 will push it around without brakes on T@B.
You really need to install some type of brake controller; your old one wired or a new wireless.
In other words, you were given some spectacularly bad advice even if your trailer really was only 2k loaded, which as MuttonChops notes, it surely isn’t.
That being said, I did already order the Curt Echol brake controller which goes in the 7-pin adapter. From the reviews, it seems that half the people love it and half hate it. I guess I'll find out which camp I fall into.
2017 Dodge Durango AWD with Tow Package IV
A can of Skyline Chili in the pantry
https://www.tekonsha.com/mobile/products/brake-controllers/proportional-controllers/trailer-brake-control-proportional/TzaIxkVx1cI5XOy!osRB508pViEKmVBf
(Prodigy’s site also has a better copy of the quick reference that is attached to the back of the hand held unit.)
The recent recall on the RF/Bluetooth replacement kits for 902501 is apparently due to a missing warning in the documentation. Some 7-way connectors won't brake via foot pedal if your 4-way flashers are turned on.
It is available on Amazon also.
Forum install question answered here:
https://tab-rv.vanillacommunity.com/discussion/comment/133858#Comment_133858
