Hi, I have a mystery issue. It "seems" that the fridge is draining alot on my T@B battery during transit. I have confirmed that I have power at the 7pin connector on my tow vehicle but it would "seem" that the power isnt getting back to my T@B batteries. For example my batteries went from 100% when I left camp down to 90% after an hour andca half long trip with fridge on the 4th bar of power on the fridge. Is the fridge just draining that much battery even though I'm getting power from my tow vehicle? 10% in about an hour and a half trip homes seems like alot. I turned off the battery kill switch when I got home as a routine part of my "arrive home" checklist. I also use the Curt Echo wireless brake controller that plugs first into the 7pin and then the camper plugs into the back of the brake controller, so there could be a problem there maybe but I dont know how to check that. I just cant think if what to check next. Help is needed and appreciated!
0 ·
The issue with the vehicle charge line is it may not provide that many amps to start with (more of a trickle charge) and then you loose some power just getting from tow vehicle charging system to tab 400 battery in back of trailer. Undersized wire doesn't help either.
If it is two way fridge, that is pretty energy efficient, I can run that on the factory solar indefinitely with some 🌞
It's a 3 way fridge. I bet that's it, its draining too fast. I've only noticed it my last two trips but it could have been doing it all along and I just never noticed. It has been in the 90s too for my last two trips so maybe it was just the perfect storm to drain the battery. I think too, I used to travel with it on the 3rd bar of cold, and I think I did have it on 4 this time.
I think you might have figured it out. Thanks!!
Thanks! I guess nothing is broken!!
I've heard it's not safe to travel with the fridge on propane. Any truth to that?
For the usual short trip home, I will just put fridge on a much lower power setting. I've been putting it in level 4 out if 5 so since fridge, but since contents are very cold, I'm sure I can put on level 1 or even off and do fine.
I wonder what people do on long trips?
I'm still going to research is the wireless brake controller might be blocking or reducing the power coming from the TV. Since it plugs directly into the TV 7pin and then the camper plugs into the back if that. It was a brand new product last year so maybe this is an issue no one realized at first.
Thanks!
Alan & Patty
Southern Az
The 3-way fridge bypasses the internal thermostat in 12v mode. The fridge is either ON or OFF, so setting it to "1" or "5" doesn't matter. It's always on.
As others have said, chances are it's simply that your TV charging system can't keep up with that high amperage demand.
Our Tacoma 'kicks down' to a trickle charge shortly after starting, no matter if we have the headlights on, have a large gauge charging wire, or kick it two or three times. It's just thinking it's smart, and probably meeting fuel mileage requirements.
It seems the prevailing thought was that successful extended dry camping with a compressor fridge (regardless of how efficient) would likely require a beefed up battery and/or a more predictably reliable charging system.
Anyone experiment with shutting off the 3-way (no Battery...and NEVER gas) while towing for 5-6 hours? Did the fridge suffer significantly, even though it was never opened while being towed?
Know there are some that loath the 3-way units and I appreciate the difference of opinion. That said, I like having options.
San Diego, CA
www.airbossone.com
