Well, mishap #1 with my new T@b happened tonight. I accidentally dropped my phone from behind the rear shelf. Any idea how to remove that piece so I can fish it out?
0 ·
https://tab-rv.vanillacommunity.com/discussion/comment/129049#Comment_129049
Actually, I keep an inexpensive tiny ratchet set that has the bits with it. Harbor Freight special.
I wrnt to Lowes in New Philadelphoa and got a right angle attachment for my drill. I set the shelf back in place but will screw it all back together after work.
Thanks @Bayliss and @Verna for your assistance!
ADDITIONAL INFO ADDED 08-20-2020: Regarding removal of the rear shelf on a 2018 320 S, see this post by @BogieMeister (includes photos):
https://tab-rv.vanillacommunity.com/discussion/11631/wireless-rear-view-camera-on-a-320-s#latest
1. You need a #2 square bit with some type of right angle driver. I used a Dewalt right angle drill attachment.
2. Lift the bin straight up, following the curve of the roof and then put to remove.
3. It's a super tight fit to get it in. Be patient and reverse what you did to remove it.
4. Once the bins are put, it is very easy to grab the phone.
I am now thinking about what kind of foam wedge I can slide into that slot to prevent a future heartache.
Sold 2023 Tab 400
Sold 2018 T@B 320S
