I have purchased a 2021 320 CS-S and plan to install a BattleBorn Lithium (LiFePO4) 100 Ah battery.  Do I need to replace NuCamp's factory installed converter?  If so, can you please explain why and what converter you would recommend?  I see some discussion from this forum in 2019 about installing a Progressive Dynamics Converter/Charger (PD9130LV).
Thank you!
                0 ·
https://www.victronenergy.com/chargers/blue-smart-ip67-charger-waterproof#downloads
To date I am unaware of other converters that reach the proper voltage, but I imagine there have to be options. I would proba ly look at some #vanlife builds.
Really, the choice of replacing the charger comes down to how you intend to use your camper.
I am leaning towards replacing the converter but not sure what that would cost. Any ideas? Thanks
2019 320 Boondock Edge - Sold Jan 2022
I know Battleborn recommended periodically using a NOCO Genius charger to at least one Tab owner rather than changing the converter.
The way we use our camper (weekend trips), we have plenty of power while camping and the solar panels fully recharge the Battleborns during the week.
I have an extended trip coming up and will be taking a generator. If our camping spot is too shaded to get adequate solar charging, I can run the generator to bring the batteries up to 60-70% if need be. More likely, I'd drain them down to 20% and run the generator for a short period each day to bring them up to 40% as that range allows for full amperage to come from the stock shore-power charger.
If you are primarily using hookup sites with shore power available, than you do not need to invest in lithium batteries. A AGM battery will work just fine, and give you power for occasional boondocking trips. If you have a solar package or suitcase solar setup, the AGM will charge back up just fine, unless your power requirements exceed the available power from your battery.
we currently only Boondock for around three days at a time, and our 200 Amp AGM meets our current needs. When this battery fails or we start going on longer trips where thenAGM can not keep, then we will upgrade to a 200amp Lithium setup. We have 194 OEM solar on the TaB and two,100 watt suitcase solar panels.
The only reason to swap out the OEM charger for a lithium specific version is to allow,the lithium battery to fully charge off the converter. If you have a solar package on the trailer, especially the Victron MPPT nüCamp uses, can be setup for lithium and charge them to 100%. Otherwise, stay with the OEM converter /charger and add an external lithium charger for the times you need to charge the batteries back up from shore power, cost less, easier to install.
https://tab-rv.vanillacommunity.com/discussion/10049/converter-power-supply#latest
... it doesn't look too difficult to swap out the converter/ charger in the WFCO power center with one of the WFCO or Progressive Dynamics lithium enabled equivalents for $200-300. Given the $$$ cost of a Lithium battery, the price of a Lithium converter switchover seems relatively small if you spend any time on shore power.
If you are camping with shore power, than you are fine with OEM setup, as the converter will be providing your power, battery gets float charge, which the OEM charger will do.
The RV lithium batteries have this charging controller circuit built in, which prevents over charging and discharging the batteries to low. Think of the, a smart batteries. The WFCO charger will, charge the RV lithium battery, but not to a full 100% charge, which requires a charge voltage of more than 14vdc. The WFCO is 13.x vdc on max charge output. But it will get the battery up to 80+% of charge.
Sold 2023 Tab 400
Sold 2018 T@B 320S
