I have a 2015 T@B and would like to change the 1.8cu ft Norcold fridge.  I am looking at the Isotherm Elegance 65 as a replacement.  It is an AC/DC 2.3 cu ft Danfoss compressor  fridge with a small freezer.   I have a installed two 6-volt deep-cycle AGM batteries with 120 W of solar backup which should be more than sufficient to support this low energy  unit.  The Elegance 65 seems to be one of the few fridges that  would fit in this cutout.    Has anyone had experience with such a conversion?  Any tips for replacing fridges would be appreciated.
                1 ·
https://tab-rv.vanillacommunity.com/discussion/comment/87839#Comment_87839
https://tab-rv.vanillacommunity.com/discussion/comment/125467#Comment_125467
It appears that a shelf might be required. As far as filler strips for the cabinet, I am sure that I can get something that looks better than the plastic cover on the Norcold.
The constant heat, the cooling fan noise, and the lack of cooling in hot weather are my reasons for attempting this. I lived in mine for four months this summer and was not pleased with the performance of the Norcold.
My 2018 320s already has plenty of ventilation in the refer cabinet that is not installed on the 2021 with the Isotherm refer. I think that it will mostly be wood working to make it fit.
I also plan to check out the measurements on the pull out drawer model Isotherm. Access looks to be much easier than the swing door model.
So I think it will not fit well.
One of the factory pictures is in the back of a T@G or similar. I hope to salvage the front air hoses for ventilation as well as the vent on the left side of the T@B. The propane vent/hole in the bottom storage might help as well.
Amazon sells these as well. (Only 5 left in stock-order soon) of course.
Maybe NuCamp will sell me a couple of 24" 1x4's that match?
As far as mounting goes, spacer blocks added inside the cabinet would allow for through the wall mounting. If trim pieces are installed to backing plywood that is glued and screwed to the existing trim, the Isotherm mounting flange might work as well. Once I get the refer I will be able to come up with a solution.
Last mod!!!
cheers.
I am im the process of swapping out the 3 way for top loading 12/120v compressor fridge. With no woodworking skills the cabinet mod is the hardest for me. Will post pics when done
Initially, because of the presence of that board, I considered moving the refrigerator a little further to the left, but that would have significantly cut into the newly created storage space to the left of the refrigerator. Therefore, I opted not to go that route. Also, I did not want to have all the open space on the right side where the two external vents are located, because a lot of air would then enter the trailer. Having the right side of the refrigerator closer to those vents will also greatly assist in ventilation of the refrigerator. Regardless, I suppose that if that board is crucial to supporting the countertop, or simply provides additional support, I can probably add a narrower piece of wood to the back right corner of the cabinet to accomplish the same thing without impacting the refrigerator installation. (NOTE: One thing I did discover while removing the board was that I had to forcibly pull the board out at the bottom after removing the pocket screws, because there is a long screw that was inserted from below the trailer and into the base of that board [see red arrow in photo below.] It is unclear to me why that particular screw was necessary since I believe there were two pocket screws attached in that area.)
You are correct that the cabinet door for the storage compartment below the refrigerator is ideal for covering the space to the right or left of the Isotherm refrigerator. I ordered one from nuCamp yesterday, via Missouri Teardrop Trailers, (Part I.D. No. 40-00-2382), but it will not be shipped until after New Year's Day, because nuCamp is currently closed for the holidays.
Thanks for the info!
