Glycol tank
Kentsb
I just got my 2021 320 CSS back from the dealer who was doing warranty repairs. One of the repairs was to the Alde temperature control valve. When the system failed I was reviewing the Alde manual to see if I could figure out the problem. What I discovered was the typical left hand does not know what the right hand is doing. The Alde manual says to periodically check your glycol levels. I could find no glycol expansion tank with or near the Alde. Thinking that the reference was being made by Alde it seemed logical that it would be near the Alde system. I just learned that depending which NuCamp you have determines where NuCamp installs the tank. In my case under the bathroom sink behind the toilet. No where near the Alde and not visible. Last place I would have guessed. It would be handy for NuCamp to document this to avoid problems. The Alde manual says if you need to add glycol do not mix different types of glycol, as it could cause coagulation. I did a search here on the forum for “glycol” and found nothing stating what type of glycol is factory installed. I can find nothing in the documentation from NuCamp providing this information. What type of glycol should I use if needed?
I know this was a very long winded post to get to my question but my objective is two fold. I find that most NuCamp owners are not happy with manufacturing problems but often just figure out work arounds or fix it themselves. By not putting the burden on NuCamp they are not able to improve the quality of their product for future owners. I worked in manufacturing for 40+ years in all aspects of operations. If there is no cost incurred by the manufacturer for defects in workmanship, design or documentation that is incomplete it is unlikely to be fixed. So I encourage everyone make sure you push your dealer and NuCamp to make things right and to improve where needed. I have worked directly with NuCamp on issues and they absolutely want to make things right. They can’t if they don’t know. Like everyone they are very busy and probably don’t have the time to read our posts here.
52 nights
2
@Kentsb https://www.amazon.com/dp/B01BDWQXM2
And I've heard rumor they do peruse the forums. The evolution of the brand would seem to confirm that hypothesis.2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
Century Transfer fluid is the recommended glycol for the Alde.
Transfer fluid = Glycol. Obvious right!
52 nights0 -
Here is the Century glycol at Amazon. And, be wary: there are two listings for the glycol....one sells for 24.99 and the other for 29.99!And, a thread that shows the locations of all the glycol reservoirs in all models.
Towed by 2014 Touareg TDi1 -
And this forum and this forum is sponsor My nüCamp, and it provides, to a large degree, customer support. The nüCamp warranty is great, and honored by nüCamp, I have not had any issues getting supoort a d warranty repairs done.
The dealer, as part of their walk through the TaB, should have shown you where the Alde expansion tank was located and how to check the level. The nüCamp manual offers an overview of the trailer and its systems.
While I agree it would be helpful to include this info in the T@B documentation, the subject of glycol has come up many times on the forum--most recently in this discussion from just last week.Kentsb said:...
I did a search here on the forum for “glycol” and found nothing stating what type of glycol is factory installed. I can find nothing in the documentation from NuCamp providing this information. What type of glycol should I use if needed?...2015 T@B Max S (320)
2015 Nissan Frontier SV V6 4x40
- 144 Events & News
- 415 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
