dlb
Member Posts: 167
I am planning on ordering a Tab 400 in the next month. In conversations with the dealer in the area they sell mostly directly off their lot and not customer orders. Therefore, I am on own designing my solar system. I have read a lot on the forum but am not an expert by any stretch. In order to get what is desired, I need the help of this forum’s wisdom designing what is needed.
My plan is to order the Tab 400 with the Boondock package and supplement the solar with a suitcase unit of about 100 watts that I will purchase separately. My desire is to have all the solar panels connected to a single solar controller, with a lithium battery and a shunt to monitor the system.
My questions are:
Can I have both the rooftop and suitcase panel coming into a single smart controller?
If so:
What is the standard solar controller on a Tab 400? Is it the Victron SmartSolar MPPT 75/15? Is this adequate for my desired set up?
If not,
I see some have the Victron SmartSolar MPPT 100/20 will this be adequate?
How are the two panels connected to the controller? I assume that connecting in parallel is what is needed. Correct?
I see some setups with Zamp connectors and solar ports being used to connect the suitcase to the trailer. Is there a standard Y connector that can be used for each panel to plug into prior to connecting to the controller?
I plan on having a Victron SmartShunt, how do I determine which one is needed? Battery size?
The last part of the system is the battery, I am thinking of lithium instead of AGM.
Our primary use for the Tab 400 is to travel the US and visit many of the national parks. Trips will be up to 3-4 weeks where boondocking will be the primary camping method.
Thanks for your help.
Aims Power Pure Sine 1200W inverter
Solar Panel: 162W Sunflare (FLEX54-162W)
Solar Controller: Victron Energy MPPT Solar Controller 75/15
2007 Toyota Tacoma V6 Access Cab
San Francisco, CA
I will order the Boondocks package for the factory solar and follow the information from Denny16 for the suitcase system.
Thanks again!
2020 Audi SQ5
Thanks to all.
2020 Audi SQ5
SW Colorado
SW Colorado
SW Colorado
SW Colorado
There have been several discussions about this over the years (here's a more recent one), many of which make it seem far more complicated than it is. Regardless of what approach you choose (swapping leads, new wiring, or a commercial adapter) just be sure to carefully confirm the polarity of all connections relative to your equipment and all will be fine!
I have a 2021 T@B 400 Boondock, which has factory solar on the roof, but it does NOT have an auxiliary solar jack.
SW Colorado
SW Colorado
SW Colorado
1. Black wire coming from negative side of charge controller (Renogy).
2. I had purchased the MC4 - SAE adapter on Amazon which if used puts the exposed metal connector on the red positive wire.
3. The MC4-SAE adapter came with an adapter that makes the exposed metal connector on the black negative wire.
That would go into the lower end of the SAE plug on the outside of the T@B which the multimeter shown to be the negative.
Doing that should work and prevent a fuse blowing. Maybe there's something non-standard about that MC4-SAE adapter which is why they provided the adapter. Next time I'll look closer to see before ordering. Hopefully this works.
SW Colorado
One of the concerns I've had about the SAE plug is that the connection with the incoming wires does not seem that secure. On our previous camper there was a nearby bracket I could secure (with big twist ties) the incoming wires so the weight of wires wasn't pulling down on the plug connection. There's nothing like that on the side of the T@B. I'll figure out something.
SW Colorado
2013 Tundra TRD 5.7L
Massachusetts
