I'd like to shut down any unused parasitic draw while camping at night. I've narrowed it down to the night light in the shower and the Jensen entertainment center. I realize the shower light probably needs to stay on, but has anyone devised a simple on/off switch for the Jensen?
0 ·
Central,Fl
2015 T@B Max-S
Central,Fl
2015 T@B Max-S
We did this more to turn off the display for sleeping, verses the hassle of dimming it way down, then way up when you want to use it. The reduced parasitic draw is a second benefit.
https://www.amazon.com/dp/B07SC27364?ref=ppx_pop_mob_ap_share
Dorman Conduct-Tite Rocker Switch 84880 | O'Reilly Auto Parts
Put it inline in the 12 volt wire and also the ground into the ground wire. Switch works but the light in the switch does not come on. Switch the load and power around, switch worked but no light. I then ran the ground directly to the ground bus, same result. Got another brand of switch, same results, switch works but no light. What am I doing wrong here?
with a different switch. Switch works great but the light does not come on. Thanks
Can you explain more?
Toronto, Canada
Wish I had thought of that.
Mine is not so . . . .
