I am hearing my Alde system gurgling, so I checked the expansion tank. I found that the fluid was at the minimum mark and the filling cap could not be screwed on very tightly. The threads on the tank [or cap] appeared to be stripped. I can certainly pour more glycol in the tank, but I am concerned about having the cap be securely tightened. I didn't find any leakage; however, it may have evaporated. Any ideas on what is going on and some solutions?
Just some background information: I had my T@B 320 in for service at the dealership and to have the Alde system to be repaired. Well, the dealer fixed the Alde hot water problem but not the heating. I had to take it back. The dealership seemed to solve the heating problem by filling the glycol tank. Apparently, the tank was empty. I have had my T@B for just over 2 years, so it sounds like the glycol should be replaced.
2 ·
The Adle CAP on my unit is also weird. Starts to screw on then pops like the threads are bad. That said have never found it completely off the tank ever after 40-mile gravel / washboard roads.
My Adle seems to need a cup or two of fluid every 3-months or so . . . no idea how it disappears.
Plus being lazy or ??? will most likely delay changing the fluid until it is 5-years old.
BTW, The 'standard change' that NüCamp does only changes a gallon or so of fluid. To do a 100% change takes more work and equipment.
Edited 01-17-21; See @mona post & @Sharon_is_SAM reply to mona below
Besides the fact that its location is not mentioned in their manual- once you do finally find it, it takes some serious acrobatics to get to it, to judge the glycol level, and to fill it to the correct level, with some improvised dipstick. I understand that nuCamp has relocated the tank in the 2021 Tab320S, but what about us !
Its even more frustrating that all the manuals keep saying how important it is to religiously monitor this level, but the tank's location makes that is so hard to do just that.
I had an idea to rout in a hole in the wood panel that lies in front of the tank, the size of an oversized electrical switch cover, or core in a 4-in dia. hole the size of a plastic snap-in black cover. Then I could just pop off the cover, see the level and know what's up. This will need to be done very carefully with a temporary protective steel plate squeezed in front of the tank to prevent it from being punctured during the proposed surgery.
Before I go ahead with this, I'm curious if others have had similar ideas, or have come up with different creative ideas to overcome this difficult situation. Also, please tell me If you think that what I am planning to do is a mistake, and if so, please tell me why. Thank you.
When you're working with such limited square footage, absolutely everything is a compromise.
That said, we made the glycol tank easier to get to in our 2015 by removing the screw that held down the back cover of the headboard, and mounted some velcro to hold in place. Now I can just open it and take a look without tools, and we prop it open in really cold weather to let the heat out. Not sure if that would work for a 2020.
2022 Ford F350 Tremor | 2022 Cirrus 620
A hole saw sounds precarious to me, I always have a hard time controlling them plus the drill bit extends deeper than the saw. I'm a router lover.
What was it like to disassemble the rear cabinetry? Other than the accessible pocket screws, are there any other difficult-to-access connections? How long did it take you. I may abandon my drill in place plan and use your approach if its straight-forward and just a couple of hours of work. Thanks
Another option (maybe a moot point now) might be to replace the panel screws with threaded inserts and thumb screws to facilitate tooless removal.
Regardless, while keeping an eye on your glycol level is well advised, it probably isn't something you need to obsess about. I check mine periodically, and I've had to top it up exactly once in six years. More top-ups might be required if your run the cabin heat regularly.
I used a felt tip marker to make the "min" and "max" lines more readable on my tank which helps too.
Let me know how it goes and if you have any more questions!
https://tab-rv.vanillacommunity.com/discussion/13070/permanent-side-to-side-sleeping-for-t-b-320-s/p1
I had to chuckle when I saw where the convectors are mounted...that's exactly where I decided to put mine instead of back on the back side of the headboard.
A popular mod before the change was to cut vent holes in back shelf so the heat could rise straight up and out.
There is now already in place a perfect-sized hardened protective steel plate- a small old handsaw blade that just "threaded the needle" between the plastic tank and the unfinished plywood. (I knew I was holding onto that old blade for something!:)
I think that I will shoot for a hole diameter that I can cover up with an easily pulled out soffit vent. This will cover the hole and also achieve some flow of heated air when covered.
If I go with the circle, there are a few few options. Thought you'd get a kick out of my idea to use a sawed-off ring from a PVC toilet flange as my control template. Then go with a router bushing against the PVC ring.
Thanks again for your helpful comments and support. Your ideas and thoughts are always welcome.
@ScottG.. I hope that you are right that one need not get obsessed about the glycol level. I had some crazy things happen after 9 days and nights of constant Alde use recently out on the road. My glycol spilled onto my friends driveway two weeks ago, probably thru the exp tank overflow, and my glycol level, when finally checked was way down, with nothing in the tank. After some unexplained fluctuations, the glycol level seems to have settled down.
I wouldn't go to the trouble of installing the port if, once you removed the wooden triangular side panel, you could actually see the level. I'm literally using "finger braille" to find my min and max, and a wooden dipstick to judge the level- the whole thing is nuts. All that being said, I'm sure that you are right and that it will not really be an issue over time-- unless of course, I heaven-forbid puncture the tank trying to install the port
Have a nice weekend.
That darn Cap has Never screwed on soooo easy.
Big Thanks!
North Texas - Retired Air Force
Trips - 46 Mileage - 58,461
I noticed you've already pulled the tank and opened the low point drain. When I pulled my system apart I ran into the same issue of pockets of glycol that couldn't gravity drain. In the driver side bench I unscrewed the convectors so I could raise them high enough to drain, then removed the hoses and plugged them. The passenger side was a different matter since the glycol lines ran to floor level and prevented my raising the convectors high enough to do any good. My system had so much corrosion that I had to replace everything but the boiler.
As deeply as it sounds like you're getting into yours I would suggest a couple of ideas. One, I added a second gravity drain in the passenger side rear bench area. I located it in the mirror location as the existing driver side drain (see pic).
This eliminated the pocket of glycol that can't make it over to just the one drain. Secondly I positioned my new hoses and convectors with a slight slope so when I pop the drains all the glycol will flow to one of the two drain positions (I positioned the hoses/convectors with the trailer perfectly level). Instead of mounting a pair of convectors one on top of the other I separated the input/output ends of the convectors by about 1/4" to create the intended slope. I used quite a few hose mounting brackets to maintain the intended slopes of the hoses throughout the camper. Net effect is when the camper is set level there are no "level" positions for any of the convectors or hoses. When I refilled my system I pumped the glycol through the new passenger side drain. If my "slope theory" was executed properly that should have allowed the system to fill and let all the air be pushed up toward the tank. I had very little burping after running the glycol pump on high to force any remaining air from the system.
@SolidCamper, I do like the PVC router guide bushing idea! I've found creating jigs to be as much fun as the actual woodworking process! I decided to forego the reservoir viewing port on mine since I ended up totally rebuilding the rear cabinet area. You can look at my post of that woodworking project in my post "Back Shelf Rebuild or Post Corrosion Fallout".
