Put a down payment on a 2018 T@B 320 S yesterday. Picking it up next Friday. My wife and I retired last year and are looking to see some of this country while we still can. Came here to get the inside scoop on these trailers and found much more. Great place!
I'm sure to have many question, but right off the bat here's a simple one. The tongue box is different than any I've seen. Is this an aftermarket item? I'm trying to figure out how good (or bad) of a deal I got, but there seem to be limitless configurations from the factory. Or is that just my imagination?
Looking forward to following the discussions here and learning from others. Thanks for having me.
I replaced the truck tool box on our TaB400 with the new Aluminum tub box they are using on the 2021 model TaBs.
TaB as purchased with truck tool box:
dheers
NuCamp is well aware of the problem and has issued a service bulletin on it.
https://us.v-cdn.net/5021717/uploads/editor/n5/2ixvw7iu9dd2.pdf
Did you notice any soft spots or bubbly areas on the floor that raised a red flag when looking at the unit ? Since you are buying this unit used ......there would NO NuCamp warranty in place that would take care of this very costly and complicated repair . NuCamp is pretty great , but covering a floor replacement on a used 320 is a stretch (anything is possible though!) . I dont think the dealer would have ANY warranty that would be covering a floor replacement problem as its a used unit ether. NuCamp can repair it to the tune of several thousands of dollars if there is no warranty coverage .......yea its a major job !
Just make sure you double check your vin number against the NuCamp service bulletin , or better yet .......CALL NuCamp MONDAY with the VIN # and see if it was in the "Green Core" serial number range . If it is ............ back out of that deal NOW . We have an Early 2019 320s , and it was luckily, out of the "Green Core" range .
Not trying to be a kill joy, just want to let you know , the year 320 you are purchasing (used, with NO warranty) , might very well fall within the "Green Core" problem range . Just something thats worth checking on NOW , before you finalize the deal . Hopefully its not a "Green Core" tab, and everything will be good to go for you !
Here are a few threads about it here .......
https://tab-rv.vanillacommunity.com/discussion/8896/2018-t-b-400-subfloor-service-bulletin
https://tab-rv.vanillacommunity.com/discussion/8937/underlayment-in-t-b-320-t-b-400#latest
Congrats on the new (hopefully, non "Green Core" ) T@B 320 !
2024 NuCamp T@B 400 BD, Grey / White
As for the Green Core floor issue, not all 2018 TaB had this issue, most were on units made from November 1st, 2017 to January 31st 2018. You can look on the nüCamp builder’s sticker on the left side of the frame and see the month and year it was actually built.
Congratulations! I hope you love the process of getting to know your fabulous little tiny home away from home as much as I have!
nuCamp discourages use of WDH's on these units. The sway is, as mentioned, cheap insurance. It doesn't impact any weight distribution to/from the rig. You'll need to have the proper ball welded to your hitch to accommodate the sway connection to your TV.
Be aware that the degree to which you increase the friction control arm on the sway bar may have the effect of the displacing the kotter-key used to secure the bar to the trailer. Keep it tight but no too tight and put it in from the top down if possible. Generally, when tightenting the bar, once you feel some friction go another round or two at most. And you may want to install a wire cable on the A frame of the trailer that connects to teh kotter-key so if it does work loose, you don't lose it. Ask me how I know. Keep a few keys in whatever you use to stow your hitch equipment.
Good luck and enjoy!
San Diego, CA
www.airbossone.com
It is also really important that the RV dealer does not top up the Alde reservoir with any old glycol. The manufacturer requires "Century TF-1" only and if you mix in some other glycol, it could gum up the Alde.
I'll sneak in one more: get all the fuses before they blow, especially the teeny tiny ones for the Alde. https://tab-rv.vanillacommunity.com/discussion/3512/fuses-for-newbies/p1
Were you able to find the build date on the front sticker ? , That little bit of info, can save you LOTS of headache down the road ! Again, just an FYI .
Oh , also anther FYI . That unit is currently on Ebay , still getting bids . One more day to go . Wonder if the dealer is waiting to see if the ebay auction will net more than you paid for it ? Something sounds fishy ....... Caveat Emptor .
Hope everything works out for you , and everything is good to go !
Good luck with the new T@B , and hope everything goes well with your delivery on Friday !
They have LOTS of lovely T@Bs
We have seen numerous T@Bs for sale in FL starting late summer 2020 up to now.
When we were looking for a T@B in 2019 we couldn't find any for sale in FL and ended up driving outside of Atlanta to get ours.
There may be a glut of them on the market once this Covid crap starts easing up.
A lot of people ran out and bought campers thinking that was the safest way to vacation. They are now realizing it takes work to maintain a camper, also work to camp successfully and are ready to go back to camping in a hotel with room service.
Tampa FL
Instead of the integral cassette toilet, like this:
They have an awkward retro-fitted one like this.
Just so you're aware of this during your T@B shopping. Here's the full posting:
https://tab-rv.vanillacommunity.com/discussion/comment/157214#Comment_157214
Are there any problems with them?
Why were they used?
We picked ours up last month and this unit does provide more room for storage in the bathroom. My wife loves it. Just wanted to be sure there were no issues to be concerned about.
