A couple of 400 owners on FB have reported their batteries have drained when they left their trailers parked, apparently with the battery switch off. They return to a trailer with an inverter alarming and a depleted battery.
I looked over the Unofficial 400 Resource Guide and the writer points out the battery switch does not turn off the solar to the battery or turn off the inverter. The inverter, apparently, has to be turned off separately.
So, what would the parasitic drain of the inverter be? Anyone know?
https://www.aimscorp.net/1200-Pure-Sine-Inverter-with-Transfer-Switch-UL-458.html
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
Same issue through, it needed to be turned off when not in use.
My guess on the newer setup is three outlets hooked to the inverter are providing inverted power ALL the time when the unit is turned on and NOT shore power when you are plugged in, but ONLY a guess. The key is they don't work on shore power unless the inverter is on AND the inverter and shore power can't be supplying power simultaneously because they of electrical code, safety and matching the AC phases.
The Victron line of Multiplus are a line of inverters, chargers, auto transfer switch and power boosting devices for instance that are way more sophisticated than the supplied AIMS unit and at several times the cost they should be. Those can match phase and in fact combine inverted power with shore power if you need more than a low amp shore power can provide for instance. Another example, excess power can be pulled from the batteries and combined with say power from a Honda 2200i for getting short bursts of extra power up to the 30a you can use in the camper, starting the AC, running microwave with AC on, etc. Of course you are limited on reserves for this boosting ability by your batteries.
My plans when funds are available is to add a Victron MultiPlus, but the cost is probably more than most here would consider, but for boondocking could be worth it.
Though speculating, am I correct in assuming if the battery disconnect switch has removed the battery voltage AND there is no campground power BUT the solar array is producing greater than 14 or so volts will the camper have power (within the solar's output capacity)?
managed by VE Smart Network
Concord, NC
Brad
Concord, NC
Went out today and tried the inverter button. Heard the inverter start up and the three plugs in the 400 connected to the inverter worked perfectly, so the inverter isn't the problem. I'm now wondering if one of my batteries are bad. Nothing indicated on the Victron app but I'm thinking the batteries hold enough of a charge to manage the lights/plugs but not the necessary amps for the Norcold 3-way. Not that proficient in electrical work but there has to be a way to check the batteries.
