Just wondering if anyone uses a lithium battery as a backup for the primary battery once it is spent. We have a Goal Zero Yeti 1000 with a Nomad solar panel, and in the past we have charged the Yeti with solar and then plugged our camper into the Yeti AC port as needed. We hate that power is lost in the DC/AC conversion, so we are looking for a cable to connect the Yeti 12V output directly to the battery cables coming from the camper. Can anyone share a source for such a cable or any other ideas? Sorry if this issue has been covered...I've been reading the discussions for hours and cannot find anything specifically addressing this question. Thanks!
What size battery do you use? I'm thinking of updating my current solar banking and am just learning about how to do this. I have yet to determine exactly what I have installed which was after market but prior to my purchase. I understand the lithiums are much more powerful. TIA!
I believe the Anderson Power connector has a higher amperage capacity than the 12V cigarette lighter outlet. How about this Anderson to ring terminal connector?
Amazon.com: Valley Enterprises Wire Power Supply or Battery Cable with Anderson Powerpole 45 Amp Connectors and 3/8 inch Terminal Rings, 10 Gauge Wire, Length 6 Feet: Automotive
It is 6FT and 10GA, so it can carry most loads you may run from the Yeti. The only thing missing is an inline fuse, but I think the Yeti has circuit overload protection (mine is pretty new to me, so I'm not CERTAIN about that last statement).
2019 320 Boondock Edge - Sold Jan 2022
Marceline posted a Yeti accessory cable that will combine the various Yetim12 VDC outputs to get a max of 40 amps. You cloudless use the Anderson and Auto power point outputs to get 20 amps.
Yep @Denny16, the Yeti 1000 does have those tech specs. I based my comment on my knowledge of my Yeti 1500
12V car port (output): 12V, up to 13A (160W max), regulated
12V High Power Port (output): 12V, up to 30A (360W max), regulated (front face/under lid)
Glad you had the free time to research...
Edit: Scratch that. You need something to regulate the charge, so either some type of adapter for the 7 pin connector or use a smart charger from the Yeti AC outlet.
