So, I am still in the process of deciding what kind of battery(ies) I want to use in my 2016 T@B 320 CS-S. Will one 12V Battleborn Lithium battery provide me with as much juice as two 6v AGM batteries using my 140 watt Zamp solar? Our fridge only runs on 12V, no propane. We will be boon-docking or dry camping 3 or 4 days at a time. Will be running the ceiling fan as needed at night - but really overall light usage of electricity. I just need to know if one quality lithium battery will do the trick.
0 ·
managed by VE Smart Network
@elbereth is right. Many people ending up killing their first battery or two until they get the hang of it. Some even after they get rhe hang of it, lol. Harder to kill lithium, but you are probably looking at $1200+ for lithium between the battery and the converter upgrade. Also, I have seen FT RVers indicate that their lithium batteries were not on track to meet the life expectancies promised.
Well maintained lead acid batteries and AGM batteries can last 6-8 person.
Also, lithoim batteries will need to be removed during cold weather, where the AGMs hold their charge when the battery switch is off for moniths.
Wait until you get a few months under your belt before making big investments.
I am a big fan of lithium, and carry a "solar generator", which has a lithium battery, but we have a way to go before it reaches the right price to make ithem a good return on investment for the average person. I am glad to see more competition enter the market to drive innovation and lower costs.
This was a very eye-opening comparison between Battleborn LI batteries and several AGM and flooded cell batteries. About 7 minutes in the summary results are given.
I don't see the converter swap as being that necessary, if you have solar. You can program your Victron to make up the difference if you want to charge them to 95 or 100%.
But keeping the Lithium batteries above 35F is crucial... yet easily managed. Add a $15 adjustable digital thermostat and $20 of low wattage heating pads, along with some Reflectix to each battery, and you're fine. In an insulated enclosure, you don't need more than 30W to keep each battery above freezing. That's all Battleborn uses in their heating kits to retrofit their non-heated batteries. Just make sure you have enough solar to keep that going all winter, including cloudy days, and days with snow cover all over your panels with road conditions not letting you get to your camper. That is, if you're not fully disconnecting your Lithiums and bringing them inside for safekeeping over the winter.
For the winter campers, the Thornwave smart shunt monitor comes with an extra programmable relay trigger. So you can always have a full battery bank disconnect triggered anytime voltage drops below 11V to handle conditions like that as an extra safety factor to save your batteries (with the solar charging line on the far end of the disconnect relay so it doesn't charge a cold battery). Will Prowse also pointed out in one of his videos that you can always use a Victron networked temperature sensor and a Victron solar controller to prevent charging a battery below 35F. All of that is if your battery vendor doesn't have that built into the BMS (like the Ampere Time LiFePO4s sold on Amazon for $400-500 per 100Ah, which do not have cold charging protection).
On the other hand, there's plenty of rumors for another leap in battery technology in the next year or two. So why spend an extra $1k+ now when the next generation might have even higher energy densities, charge even faster, and be even lighter. So sticking with AGMs for a couple more years might make sense for most people too.
The reduced weight and increased useful power of Lithium was very tempting.
However after reviewing how I actually camp decided a group-27 AGM and cheap generator was best (already have 150W portable solar). Why?
For me the two biggest concerns are dead battery in morning i.e. cannot run Alde for cabin heat or need for a bit of air conditioning in the early evening . . . while Lithium greatly reduces the likelihood of a dead battery in the morning they are zero help for running the A/C . . . . so for less $$ then one Lithium battery I've got a quality brand AGM and a cheap (red Chinese) gas generator just big enough to run the A/C and plenty big enough to run Alde while recharging the AGM on some cold fall morning.
Since making this change (upgrade?) have used the generator twice . . . both times due to my incorrectly judging how much battery power was being drawn . . .
Here's a handy reference: https://batteryuniversity.com/learn/article/charging_at_high_and_low_temperatures
@r@rmcarthur - I experienced a completely dead battery on my first trip out in my "new to me" T@B. Partly because I inherited a half-dead, mistreated battery from the previous owner and because I didn't know not to run the fridge on "battery" while en route.
I almost exclusively boondock and as a single female traveler, the lithium battery is akin to always having a full tank of gas. I am also a very analogue camper (my day job is in high tech) and have very low power requirements - I run the Alde/fridge on propane, water pump, and minimal interior lights. But I carefully monitor its charge level with a Bluetooth app, recharge it on solar when possible, and I pull the 30 amp fuse when I'm not using the trailer so that there is no passive drain on the battery. Fingers crossed that this battery lasts me a good long time! I've had some great mentors @m@Marceline @p@pthomas745 and @s@Sharon_is_SAM, among others :h:heart:
My T@B also came without a battery cut-off switch. After a couple of years of pulling the fuse I finally installed a switch. Wish I had done it earlier.
https://youtu.be/iy3hga_P5YY
After watching the Will Prowse video coupling a Victron Battery Sense for low temp protection with an Ampere Lithium Battery, I just purchased the Ampere 200 AH. Including the Battery Sense, total cost was about $650 w/free shipping from Amazon. Original price$799, then -$50 Amazon coupon available on the site and -$150 after immediate approval of no-interest credit card. Not a BattleBorn, but with Prowe’s recommendation and Battery Sense, seems like an good risk. Time will tell.
1. USA Built
2. I have seen ZERO negative reviews
3. Highly recommended by Will Prowse
4. 10 Year warranty
Got a quote for a few dollars off their sale price and pulled the trigger this afternoon for 2 x 100 Ah. Since this is my last RV they will last me the rest of my years of camping and then some.
Brad
Concord, NC
So, my AGM’s have an expected lifespan of 6 to 10 years, and I’ll be betting the Lithium batteries (or the newest, latest, greatest batteries) at that time will have their technology down pat. That’s the way technology is…it just keeps getting better.
My 150 pounds of two year old AGM's have been regulated to backup power for our sump pump.
