Repacking Axle Bearings
2»
    edited January 2016
    Boo -  Why not just cut some plywood to size pads (4 pieces) to place beneath the jack stands, jack up the corners of your trailer and place the stands on the corners of the trailer frame?  You wouldn't have to worry about the stands sinking into the ground after the frost is gone and if you are worried about the jack stands contacting the frame you could also place some strips of wood between the stand and the frame.
  • sabelsabel Member Posts: 283
    Does anyone know if you have to remove the wheel to access the bearing grease fitting? Or can the bullet shaped hub cap be removed while the wheel stays on?
    Sabel - Last time I had the bearings greased (actually, all three times), the guy took the wheel off and pulled the bearings - said he wouldn't use the grease zerts for a repack as they feed to the back of the hub and you can't tell when to stop. Too much and it ooozes out the back into the hub and brake assembly. Fine for periodically adding a squirt inbetween repacks though.
    Since they recommend inspecting the bearings yearly, guess I'll have them do the full monty.
    thanks
    Oh phew @sabel, I thought you were going to GIVE them the full monty. LOL.
  • glesieutreglesieutre Member Posts: 26
    edited June 2021
    My zerk fitting on one side doesn't seem to be accepting grease correctly. Any suggestions?
    2015 T@B S-Max towed by 2016 Subaru Outback 3.6R -- central Pennsylvania
    "Travel is fatal to prejudice, bigotry and narrow-mindedness." Mark Twain, The Innocents Abroad, 1869
    You could try unscrewing te Zerk and getting a replacement from an auto parts store.
  • ScottGScottG Administrator Posts: 5,647
    @glesieutre, has it worked in the past? When was the last time you added grease?
    edited June 2021
    @Denny16 Thanks, good idea. I removed it and there does seem to be a little damage around the ball. Strange. Do you happen to know if Dexter parts are metric or English? Or, what size this is? (If I had to guess, I'd say 1/4"-28.)
    @ScottG Yes, it has worked in the past, and the one on the opposite side seems to still work well. Last grease addition would have been about a year ago (late July). Not much travel since then...
    Thanks!
    edited June 2021
    @glesieutre, I suspect that the zerk is 1/8" NPT
    Brad
    P.S. A couple other comments regarding some of the other responses.
    1. You should never mix different types of wheel bearing grease, it can cause the grease to get "clumpy" with bearing failure to follow
    2. You should always replace the seals whenever you service the wheel bearings, inexpensive insurance
    3. I would not ever pump grease in until it returns out through the front bearing. The hydraulic pressure could easily push the seal out of place and allow grease into your brakes.
    2020 400 BDL aka "Boonie"
    Concord, NC
    @Dutch061 The outer thread diameter is definitely less than 7 mm and appears to be tapered. Thanks for the other advice. I'd planned to have the bearings inspected and probably replaced after a pending trip.
    You can get the Zerk in both metric or SAE (Imperial English) threads.
