I was just looking at the Renogy web site. They are advertising a new battery line. There is a 200Ah battery with built-in Bluetooth for about $1000.
They also have a 100Ah version for about $500.
I don't have any other details, but thought some folks would find it interesting.
2019 320 Boondock Edge - Sold Jan 2022
You can also barely make out the polycarbonate (Lexan) panels I added to the back of the tub to keep loose items from falling out. My Victron is mounted to one panel and there is a cutout in the middle panel to reach the battery cutoff switch.
Edit: For comparison the Ampere Time battery has a 4000-7000 cycle time. It does not have the Bluetooth built-in (to track it's state of charge).
12V 100Ah Smart Lithium Iron Phosphate Battery w/ Self-Heating Function | Renogy Solar
Looks like it will provide the charging protection in cold weather you're looking for. Not as cheap as the original one that I mentioned though.
The new battery is "only" rated for 2,000 discharge cycles. But that means I can discharge it every day for the next 5.5 years. That's not too bad. Or if I use my trailer 100 days a year and discharge it 80% I will get 20 years. Again, not too bad!
2017 F-150
Coeur d'Alene, Idaho
managed by VE Smart Network
It is not discharging that causes a problem below 32, only trying to charge them that can cause permanent cell damage and other more serious issues. Storing or discharging in below freezing temperatures is completely safe with BB.
I can't speak to other brands because I done my research on BB only. It was that research and other things that guided my decision on which brand of Lithium batteries to purchase and not the price. In my past experience, anytime I buy something based on price I am never satisfied until I buy what I actually wanted. There was a saying at a company I worked for a few years ago: "I would rather apologize once for the price, rather then many times for the quality".
By no means am I stating that Renogy batteries are in any way subpar or not a good choice for the OP's needs or for others. As in all things, do your own research and make your own decision based on your needs and budget. Ask others if they are happy with their decisions and if they would make the same decision again, etc.
Brad
Concord, NC
First I want to mention I don't think anyone considers your remarks disparaging Renogy @Dutch061 . Your insights to what you've learned are always quite valuable, across the forum.
I started this discussion after noticing the big price drop in the cost per Amp Hour of Renogy Lithium batteries. This past winter they offered a 170AH Lithium battery for about $1800 (price has dropped since). This equates to $10.58 per AH. The new battery I started this discussion about is 200AH for about $1000 or $5 per AH. That was something I found significant and worth sharing
Full disclosure too, I am not in the market for a new battery. After doing quite a bit of research (and fretting about potential choices), in May I purchased the Renogy 100AH AGM that I mentioned later in this discussion. I paired it with 200W (overkill) of solar for my 320 with a three way fridge that we use on propane when dry camping
During my ‘research’ phase I tried to use the collective expertise the forum. Here are some things that went in to my choice
1.Thinking about moving a battery from the tub to inside to protect from weather/freezing here:
Lithium or AGM Battery Mounted Inside a 320 Cabin? (vanillacommunity.com)
2. Wondering about the need to add DC to DC charge protection due to Lithium here:
DC to DC Charger Needed With Lithium Batteries? (vanillacommunity.com)
3. I also read several discussions related to the need to upgrade the converter to better charge Lithium batteries.
I did some measurement of tongue weight on my trailer to determine the effect of a lighter (Lithium) battery or removing the battery from the tub and shared my findings here:
What (I Think) I've Learned About Tongue Weight on a 320 (vanillacommunity.com)
Spoiler alert- Ultimately I found that even with the stock lead/acid battery my tongue weight was teetering on too light percentage wise. This helped my decision to go with the heavier group 31 AGM and keep it in the tub.
The Lithium choice just didn’t check off enough items on my Plus/Delta list at the time of my purchase. The weight and cost of the 200AH battery to start this discussion has me contemplating my life’s choices… well, some of them anyhow…
The attitude (and in no way do I sense any disparaging of anyone or any product in all of your comments) is wonderful and sharing. I too have done a lot of battery research and ended up with 2 completely different conclusions because of surrounding circumstance.
For our t@b, we have a 125 ah, flooded wet cell, group 31 battery. Paired with only 80 watts of plug in solar and 3 way fridge, it keeps us mobile and allows for spur of the moment choices and adventures. This set up completely suits our t@b needs and travel style.
While preparing for full-time rv life and travel (beginning in about a month), we have opted for a 600 ah BB battery bank, 1.4 K of solar, 2 50 amp charge controllers, and a 3,000 watt inverter, auto switched on demand. This system is on a 30' 10,000 lb gvw tt. Different life style, different needs, very different conclusion. Yes, full-time rv life. No longer calling it "camping". -Denise
