@Dalehelman said:
I understand that the auto air bleed valve must be in a level position to work properly. As they come from the factory they are not in the proper position. It should be resting in the white cradle. The problem I the top of the valve hits the underside of the seat cushion.Solution is to carve out enough material from the bottom of cushion to allow proper clearance. A large Forstner drill bit would work well.
