Let's Get Grounded!
2»
    I suspect that the fused ground is because in EU they would run this on 220 VAC which would mean 2 x 110 VAC coming in. If this is true, part of what should be done when it is converted to 110 VAC is this fuse should be replaced with a jumper. USA Code doesn't allow fusing on the negative wire or a ground circuit.
    Brad
    2020 400 BDL aka "Boonie"
    Concord, NC
    The fused "ground" in question is the negative leg of the Alde's 12VDC power supply from the converter/battery. I don't believe that differs between north America and Europe.
    That said, I'm not entirely sure how the two power supplies interconnect inside the unit, so the weird fuse on the negative leg remains a bit of a mystery and may very well relate to some adaptation from the European power supply. It's certainly curious that some degree of DC grounding appears to occur through the ground pin on the 120VAC side (see my post of August 3) but admittedly the ability to make sense of all this is getting above my pay grade.
    It's also curious that Alde eliminated the 12VDC- fusing in the newer 3020 models. I wonder if they have done the same thing in Europe.
    My 2015 never had a blown Alde fuse. I always attributed that (perhaps in error) to my Progressove EMS.
    The Alde in my 2015 has never blown a fuse, and I have no EMS. Admittedly, I probably run my Alde much less than you (@jkjenn) did--and even less frequently on shore power. It did seem like an issue that affected some units repeatedly and others not at all.
    Whether the fuse-blowing problem in any way related to the issue of bonding (a.k.a. "grounding") the 12VDC system to the chassis remains anyone's guess. It's rapidly becoming a moot point since the newer 3020 units have no fuse on the 12VDC negative leg.
    edited December 2021
    And.... I blew the Alde fuses a number of times, and I also have the Progressive EMS... 😏
    I believe haven't blown them in the time since I replaced them with the slow-blow version.
    As I have battled through the voltage drop testing and further research, I came a across a pretty handy App for my phone called Electrical Calculations. With this App, you can create scenarios to see projected outcomes based on gauge of wire, length of run, temperature, voltage, and amperage draw.
    For those nerds (myself included) that really want to have a better understanding of the Power loss that occurs, I have run several different scenarios based on 12 VDC, either a 10 Amp or 40 Amp draw, and either 22 feet (estimated length of ground wire in our 2020 400 BDL) or 50 feet (estimated length of ground and power feed wires combined).
    Please find that document attached for reference or a headache. I have also posted this in the Corrosion thread.
    Brad
    Concord, NC
  • MuttonChopsMuttonChops Member Posts: 1,835
    Well, Well I Found my Trailer's Chassis Ground
    and it is Open/floating
    In an earlier post to this thread I noted my 2018 March-2018 Build 320S did not have a chassis ground placed near the Junction Box as several owners reported.
    Today I had need to remove part of the Air-Flow-Belly-Pan and found the Chassis Ground location.
         Drivers side of inside frame,
         aft of the wheel well,
         in the general area of the Power Center and ground bus.
    Now my trailer has 35+K towing miles that includes several hundred miles of county gravel roads, a hundred or so miles of dirt (BLM, NFS) roads, and at least three winter snow storm days of wet/salty highway driving.
    End result is the Screw Head has failed and the electrical contact post is not looking so great.
    I'm thinking an occasional inspection should be added to my routine ;)
    Wow, @MuttonChops, that's an important finding!  Is this the A/C bare wire ground that goes into the floor in that area?  I guess you'll try to grip the remains of that screw & try to back it out & replace?  Or else maybe drill a new hole for a new screw.  Also wondering whether we still should have a DC ground on the chasis up front near the J-box.  I guess that ground block is aluminum?
    BrianZ said:
    Wow, @MuttonChops, that's an important finding!  Is this the A/C bare wire ground that goes into the floor in that area?  I guess you'll try to grip the remains of that screw & try to back it out & replace?  Or else maybe drill a new hole for a new screw.  Also wondering whether we still should have a DC ground on the chassis up front near the J-box.  I guess that ground block is aluminum?
    All good questions . . . afraid all I can say are opinions/guesses.
    I've not investigated the routing/connection of this wire - - other projects have my time.
    The last time I did any measurements; my DC Ground Bus was directly connected to chassis.
       While how/where was not clear.
    Before I fix this connection - - will recheck the DC ground bus - - do expect your idea that this 'floating ground' wire goes to the AC Side of the Power Center is accurate.
    Meanwhile, everything works. My "is the frame 'Hot' tester" says no and the Alde is running just fine in our teen's F nights.  So guess I'm ignoring what this open ground could mean . . . . .
    I would replace the aluminum ground block with brass, bronze or better yet, stainless steel.
    @MuttonChops, it's been a while since I've pondered this issue, but I think--as @BrianZ suggested--that is the chassis ground for the 120VAC side of the electrical system. It ensures that the trailer chassis is properly grounded when plugged into shore power, but probably has little effect on the 12VDC side which (by one means or another, depending on model year) seems to have it's own chassis ground.
  • BaylissBayliss Member Posts: 1,467
    @MuttonChops, I too believe it is what nuCamp has referred to in the past as the "main" ground to the chassis (see my July 2021 post in this discussion thread.)  In reality, it is, as @ScottG noted, the 120VAC ground.  It appears that the solid copper wire that originates in the power center/converter is connected to the metal lug in your photos.  Interesting find.  Nice to see what it looks like, which is similar to the lug next to the junction box at the front of my trailer (and other trailers, as noted by a few owners on this forum.)  Thanks for posting the info and photos.
  • KK1LKK1L Member Posts: 117
    The poor DC ground situation is exactly the reason for having a fuse on the negative side leg of circuit at the battery/inverter. If 12V chassis ground fails, then the ground could be completed through the components attached to the 12V circuit which could damage them.
    Jericho, VT
  • RobermcmRobermcm Member Posts: 94
    edited May 2024
    i havent processed all this Alde grounding info yet.  I’m installing a Victron shunt and adding a battery to the existing lithium 100ah in my 2023 tab 400.
    There is a  white ground wire coming off the Alde system, connected to the stock battery negative. I traced it back to the circuit board on the Alde boiler. Suspected it was related to the fuse issues in earlier set ups.
    Now that my shunt is almost installed, I’m wondering if I should route the white wire ground to the load side of the shunt so any draw is tracked?  Makes sense to me. Will require lengthening the wire a bit. But worth it if it does allow Alde use to be tracked.
    While I’m on this topic of adding a battery, I’ll ask about solar disconnect. How is solar routed to the batteries?    At the start of my battery add, I
          - turned off the battery connection twist switch and I
          - tripped the Gloso switch, which I’ve always tired to the converter-> battery connection.
    I checked voltage at the bus’s bar and it was 14 volts!  So I figured it was coming from the solar controller and I turned off solar charging. That got rid of the voltage, after a long bleed of a capacitor somewhere. How was voltage making it to the bussbar if the disconnect and gloso breaker were off?
    2023 Tab 400
    2015 Audi Q7 TDI
    Northern Ohio
  • HoriganHorigan Member Posts: 767
    You should move all ground wires to the load side of the shunt.
    Typically, solar power is wired directly to the battery (or shunt) and is not affected by the state of the battery switch.  Not sure on the 2023, but the battery positive should be wired to small distribution block.  The solar attaches there, as does the power source that runs through the battery switch for the trailer 12V loads.
    Rich
    2019 T@b 400
    Bellingham WA
    I needed to replace the chassis ground wire on my 2019 T@B 320 S Boondock Lite, so I figured I would post a photo showing the ground wire lug attached to the chassis, and how the bare copper wire is routed up through the floor.  While I was under the trailer, I noticed that several of the plastic hold down clamps for the electrical wire conduit/loom, were loose.  The same was true for the plastic entry points/ports where the wiring leads up into the trailer.  They don't support much weight, so it is not really an issue, but if you happen to remove the coroplast cover under the trailer to do some repair work, you might want to re-tighten those screws (they don't appear to be biting into anything of much substance.)
    It was very easy to replace the 8 gauge bare copper wire.  After removing the original wire, I found that I needed to route the new wire by pushing it through the bottom (exterior) of the trailer and into the electrical compartment.  When I tried to push the wire through the floor from inside the trailer, it would not budge.  It appeared that the composite wood below the floor was likely broken loose a bit and blocking the path of the wire from that direction.  I purchased 24" of wire, but only used 16 1/2" (but the length will vary with each trailer.)
    You may be asking why I had to replace the ground wire.  Well, when nüCamp replaced my flooring in April 2023 (to repair the "floor issue" that was a problem for trailers manufactured around that model year time period), the tech cut the ground wire, but never replaced it (see second photo.)  Over the following six months, I towed the trailer for over 11,000 miles (through western Canada and the U.S.) before I discovered that the ground wire had been cut.  I made a temporary fix after discovering that, but finally replaced the wire this past weekend.  I think what protected my wife and I from a potential electrical shock is that I have a second ground connection to the chassis at the front of the trailer adjacent to the electrical junction box (as I previously described in this discussion thread.)  Needless to say, it was a "shocking" discovery.  I shared the information with nüCamp, along with other problems I found after the floor was repaired (e.g., floor not properly adhering in the kitchen area, misaligned cabinets, and the very sloppy application of caulking.)
  • donmontalvodonmontalvo Member Posts: 150
    edited May 12
    2024 320S Boondock.
    I ended up having a second ground point on the passenger side, for my upgraded off grid power kit. It is a 6AWG stranded copper wire, protected by loom, and ending in a lug, which is attached to a sanded down spot on the frame, using a self tapping screw. Testing showed no ground loops (voltage, resistance, continuity).
    Don Montalvo | Retired Veteran | Full Time Snowbird
    2024 nuCamp T@b 320S Boondock Black Canyon (480W solar|200ah LiFePO4|1200W inverter)
    2021 Jeep Wrangler Unlimited Rubicon (130W solar|100ah LiFePO4|DCDC|1000W inverter)
    Scratching my head, this image seems to imply the busbar is "grounded" by the two phillips screws that attach it to the camper floor. Say it ain't so. :)
    nuCamp provided a sanity check. One of the white wires on that busbar goes to the chassis.
    @donmontalvo, if you read my comments earlier in this discussion, you will find that the busbar in my 2015 did indeed appear to be grounded to the chassis via the two screws that attached it to the camper floor.
    That said, nuCamp did make some changes to the DC grounding in later models so what they reported to you is probably also correct.
