We’re closing in on our first camping season with our 2021 400 BD. It’s mainly been boondocked in and what I’m noticing is that I still don’t see a need for lithium. I’ve seen many on here that have upgraded and my assumption is that these are people Boondocking off grid for several days.
We’re mainly weekend warriors averaging 2-3 nights out. Our solar keeps the battery topped off and we’ve never been in a situation where we had drained the battery (below 50%). Admittedly most of that camping was done in sunny weather but are people really using that many AHs over a weekend of camping to justify lithium? Or am I missing something? I may bite the bullet and get an accessory solar panel to help if the camper is under a tree but lithium seems so expensive.
It does add many more usable AH in same space, lightens battery weight, charges much faster, allows much larger draws without affecting the battery. If you are on shore power most of time, you probably do not get much benefit.
I haven't rushed out and made the swap on my 400, but might consider it when the OEM AGM batteries reach end of life.
Much depends on your needs. I run the fridge on propane, rarely use the Alde for cabin heat, avail myself of campground showers, and don't care for a lot of light. I don't feel like I scrimp on power to the point of denying myself, I just don't have very demanding requirements. At this point in time, I can't see dropping a grand for Lithium when I can get five years out of a basic wet cell for a fraction of the cost. YMMV.
I think the lowest our battery has gotten was 70% and by 10am the next day it was 100% because of the solar. We're fairly new to RVing (about 3 years) and can't imagine how people did it back in the day without a generator when there was no solar, battery capacity was low and lighting was incandescent.
2020 Tacoma TRD Off-Road
If lithium comes down in cost even more (which it will) I can see upgrading once our AGMs conk out. If not for the capacity but for the weight savings and simplicity of knowing we can run them down much further and charge them up much faster. But right now I think the cost outweighs the benefits for us.
I bought a 2013 T@B CS with a 2way fridge and a 55aH AGM battery + 100w suitcase solar. One cloudy day and I was done for... no chance of keeping the fridge running. So when I saw that Costco had a 90aH LiON Energy battery for a "reasonable" price I jumped on it. I was able to triple my effective battery capacity without increasing the weight of my trailer (actually reducing it). It was the best thing I've bought for my trailer. And yes, a few weeks ago I wrung every aH out of that battery when I was parked in the redwoods for four days.
Hope this clears things up for you.
Trips - 48 Mileage - 63,452
Poughquag, NY
Brad
Concord, NC
SW Colorado
Poughquag, NY
That said, I was concerned about the 200 amp AGM keeping the 2-way fridge going whilst off grid (boondocking). I discovered with minimal Solar charging during the day, the AGM maintained about 60% of its charge and a +12VDC output. The fridge stayed cold during a 4-day adventure when the local power grid was shut down to prevent fires caused by high wind knocking down live power wires.
Again, it comes down to how you camp whether it is the right decision or not. For my wife and I, my only regret is that I didn't do it sooner.
Brad
Concord, NC
A load test indicated my 3-year old original AGM’s were marginally OK and mutimeter measured a resting voltage of about 12.2 with a 60% SOC. The Norcold 2-way interior light and the circulation fan were working and everything else in the 400 also appeared to work, however, the Norcold would not cool. I think under a load, there was enough power to run some things but not enough to handle the initial surge required to start the compressor. Installed an Ampere 200 AH lithium and Victron Battery Sense per Will Prowse for temperature protection. With Amazon discount, only cost about $200 more than new AGMs with almost twice the power and a more usable discharge profile. Haven’t had the problem since.
If you are trying to operate a 3-way refrigerator on 12 VDC you are going to need a lot of Ah. If memory serves me correctly, the 3-way refrigerator draws 10 Amps plus on DC. Unlike a compressor refrigerator, this does not cycle on and off, which means in 24 hours you would consume 240 Ah of batteries without using ANYTHING else.
Brad
Concord, NC
Given LiFePO4's higher voltage, inside lights are a bit brighter and I think my 3 way Norcold starts more readily when using propane, but that is a feeling rather than an objective assessment.
Another thing I've read about Lithium batteries is their lower charging resistance/greater efficiency with resultant faster charging with solar compared to lead acid batteries. I did not test this but wonder if anyone else here has done so?
So impressed with LiFePO4 batteries, I bought a second Battleborn on sale as a backup. I am not sure if I want to install two batteries inside our camper, but I am pondering that option. They are light enough to readily swap--if needed. I like the idea of perhaps having a small 12v refrigerator in my tow vehicle that could run independently on the second LiFePO4 battery.
This winter I set both batteries up in parallel in our basement in case I needed some power backup in the event of a grid failure. I test their SOC regularly and they really haven't budged much over 3 months. They can be used to power up my EcoFlow River Pro (or any solar "generator), which has a built-in 600 watt inverter. All together they provide over 3000 watts of backup--minus operating efficiencies.
2018 Toyota Highlander, XLE
Wisconsin
A lot of people go with Battleborn batteries on here. Nice but expensive. I got an 100ah AmpereTime lithium for under $400. To your point for the frig, can search on here for high altitude issue for 3 way. I just like that I can drive down the road now with my 3 way on DC and keep it working till I get to my campsite and when I hook up it brings the battery back up. With my stock battery it would be dead before I arrived.
That said- with the price of 100Ahr Lithium batteries down to nearly $300, I'm just gonna' throw one in for this season so I've got nothing to worry about if it's cloudy for a week. They've gotten so cheap, I can't see ever buying an AGM.
