What's Your Favorite Gas Grill?
Just my $0.02, but I'd stick to something with a lid to maximize versatility and minimize warm-up times.2015 T@B Max S (320)
The one with the pork loin at 135 degrees!DaveR middleTN - 2015 320S / TV 2003 Tundra 4x42
Eureka! From boiling to simmer, simply the best heat control we could find.
https://www.amazon.com/Eureka-Ignite-Portable-Two-Burner-Camping/dp/B07T2NKBMC/ref=sr_1_4?keywords=eureka+camp+stove&qid=1639933778&sr=8-4
Thanks, Jerry
2019 Honda Pilot AWD and 2018 T@B 320-CS hanging out on the left edge of Lake Erie.1 -
I got this one and we like it. It just barely fits through the side storage door behind the tire.
Nick / 2018 T@B 320 S / 2010 VW Jetta TDI / Coeur d'Alene, ID2 -
@PNWtabber I bought this grill because it has igniter (to replace a $20 charbroil that didn’t) and it works well for me! I love the size and especially that it’s lightweight! I stow it in a cloth sack in my TV when traveling. I haven’t had any problems with it. And it was very budget friendly!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Quick and easy now.Camp Chef Ranger II stove using quick release propane connector on the 2021 T@B 320S Boondock for cooking outside.
Tried bypassing the regulator on our Coleman but I finally gave up on trying to get it to work on the quick release connection, just not enough pressure. I doubt any stove that uses the small green bottles will work unless connected directly to the tank before the regulator. This is a nicer stove anyway.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
I have a compact grill by STOK that seemed to be just what I wanted, but the only thing it would work with was the small 1 lb disposable propane canister no matter how hard I tried. Like you, even with the regulator removed.I am convinced that the pressure from the 1 lb canisters is high pressure in nature and therefore no device that uses a 1 lb canister is ever going to work at the back of the T@B.I have the Ranger II pictured above and it is a great stove. Pots and pans of all sizes fit on here more more so than the T@B 320 stove, however, it is another thing to carry and I still don't have a grill.I would still like to try out the Nomadiq that I mentioned in an earlier post on this thread (yes, I would have improvise a lid - but that's doable) - but I just don't know if it will work with this low pressure outlet.
@nbrandt - here is a thread that will help https://tab-rv.vanillacommunity.com/discussion/11344/grills-griddles-and-stoves-compatible-with-the-quick-connect-propane-port-on-2021-t-bs/p1
From the thread:
“Sounds like an easy way to determine if your grill will work with the low pressure propane port. “Get a grill that does NOT use the small 1 lb portable bottles, i.e. requires an external regulator.”
http://www.rvforum.net/SMF_forum/index.php?topic=82800.0;all#lastPost
I agree. The Camp Chef Ranger II has been solid for us. Easy to light and has plenty of BTUS.SLJ said:Quick and easy now.Camp Chef Ranger II stove using quick release propane connector on the 2021 T@B 320S Boondock for cooking outside.
Tried bypassing the regulator on our Coleman but I finally gave up on trying to get it to work on the quick release connection, just not enough pressure. I doubt any stove that uses the small green bottles will work unless connected directly to the tank before the regulator. This is a nicer stove anyway._____________________________________________________
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia1 -
Eureka 2 burner camp stove with adapter and 5 lb tank. Can move anywhere (like if picnic table is far away). Boils water fast but also allows to simmer low. Also use ASMOKE 350 portable pellet grill. Carry it around with one of those canvas firewood totes.
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one"0 -
Have had the basic Coleman stove for years
Upgraded to Webber Traveler last year, helped that I was working at an ACE during Covid
Its handy that it doesn't need a table and locks when collapsed0
- 956 Air Conditioning & Refrigeration
- 920 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
