What's Your Favorite Gas Grill?
13»
    ScottG Administrator Posts: 5,682
    edited December 2021
    Just my $0.02, but I'd stick to something with a lid to maximize versatility and minimize warm-up times.
  • fstop32
    fstop32 Member Posts: 391
    The one with the pork loin at 135 degrees!
  • Dutch061
    Dutch061 Member Posts: 765
    @fstop32, hmm I want a little less squeal left in my pig I usually take pork to 160.  =)
    2020 400 BDL aka "Boonie"
    Concord, NC
    Yeah, I like grilled pork loin, but I gotta' agree with @Dutch061 on that detail.  :-)
  • fstop32
    @Dutch061 and @ScottG, I should have clarified that I take it off the grill at 135 but foil it and let it "rest" and it will climb to 145 which is the going temp for medium rare...we like to live dangerously! :)
  • JP2558
    JP2558 Member Posts: 248
    Thanks, Jerry
  • subfreq111
    subfreq111 Member Posts: 47
    I got this one and we like it. It just barely fits through the side storage door behind the tire.
    Nick / 2018 T@B 320 S / 2010 VW Jetta TDI / Coeur d'Alene, ID
  • Homebodyatheart
    Homebodyatheart Member Posts: 2,517
    @PNWtabber I bought this grill because it has igniter (to replace a $20 charbroil that didn’t) and it works well for me! I love the size and especially that it’s lightweight! I stow it in a cloth sack in my TV when traveling. I haven’t had any problems with it. And it was very budget friendly!
  • SLJ
    SLJ Member Posts: 655
    Quick and easy now.
    Camp Chef Ranger II stove using quick release propane connector on the 2021 T@B 320S Boondock for cooking outside.
    Tried bypassing the regulator on our Coleman but I finally gave up on trying to get it to work on the quick release connection, just not enough pressure. I doubt any stove that uses the small green bottles will work unless connected directly to the tank before the regulator. This is a nicer stove anyway.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • nbrandt
    nbrandt Member Posts: 65
    I have a compact grill by STOK that seemed to be just what I wanted, but the only thing it would work with was the small 1 lb disposable propane canister no matter how hard I tried.  Like you, even with the regulator removed.
    I am convinced that the pressure from the 1 lb canisters is high pressure in nature and therefore no device that uses a 1 lb canister is ever going to work at the back of the T@B.
    I have the Ranger II pictured above and it is a great stove.  Pots and pans of all sizes fit on here more more so than the T@B 320 stove, however, it is another thing to carry and I still don't have a grill.
    I would still like to try out the Nomadiq that I mentioned in an earlier post on this thread (yes, I would have improvise a lid - but that's doable) - but I just don't know if it will work with this low pressure outlet.
    @nbrandt - here is a thread that will help https://tab-rv.vanillacommunity.com/discussion/11344/grills-griddles-and-stoves-compatible-with-the-quick-connect-propane-port-on-2021-t-bs/p1
    From the thread:
      “Sounds like an easy way to determine if your grill will work with the low pressure propane port.  “Get a grill that does NOT use the small 1 lb portable bottles, i.e. requires an external regulator.”
    http://www.rvforum.net/SMF_forum/index.php?topic=82800.0;all#lastPost
  • elbolillo
    elbolillo Member Posts: 570
    SLJ said:
    Quick and easy now.
    I agree. The Camp Chef Ranger II has been solid for us. Easy to light and has plenty of BTUS.
  • rcarlson1957
    rcarlson1957 Member Posts: 265
    Eureka 2 burner camp stove with adapter and 5 lb tank. Can move anywhere (like if picnic table is far away). Boils water fast but also allows to simmer low. Also use ASMOKE 350 portable pellet grill. Carry it around with one of those canvas firewood totes.
    2018 TAB 320S
    2020 Honda Ridgeline RTL
    North Texas
    Trips - 50 Mileage - @67k
  • screwlose
    screwlose Member Posts: 18
    Have had the basic Coleman stove for years
    Upgraded to Webber Traveler last year, helped that I was working at an ACE during Covid
    Its handy that it doesn't need a table and locks when collapsed
