Ok....next question for those with you in the 2022's: does it work ok? There has been an ongoing FB discussion today with some confusion about it. And thanks to everyone for responding.
Got the 400 a week ago, haven't tried mine either. To be honest it is a pressure regulator, I've used them in the past without a hitch, they are pretty simple devices. My build date was Nov-2021.
2022 T@B 400 Boondock 2015 RAM 1500 Outdoorsman Quad Cab South Jersey
@Sharon_is_SAM thanks, I was looking for that thread and picture myself. A person on the FB page is having city water issues, water draining from under the trailer, etc. I can't seem to convince them she should already have a water pressure regulator. All of the drains are closed, etc. The picture will help.
I also seem to remember a post about three months ago with another new trailer. They had very low pressure with an "extra" pressure regulator added to the water inlet. So, that is the reason for my "does it work" question.
Yea you wouldn't want to have the one installed inside camper working then have another one on your hose.
I think the regulator for LP actually cuts back the pressure by some percentage, but I'm not sure about the water. I think it only allows a specified pressure to pass. In that case the second one wouldn't hurt. It just wouldn't do anything, but could act as a backup if the first failed? Interest to hear from someone more knowledgeable.
Stockton, New Jersey 2020 nuCamp T@B 320S * Jeep Wrangler 60,865 camping miles through the end of 2025
This was my assumption as well. But it would be interesting to see if this was tested by someone.
Any point of resistance in a plumbing line such as an elbow or even a curve is going to slow the flow down even if it the size of pipe is the same. My thought is if the flow pressure is reduced at the source (campground water supply with reducer there) then it is released into the hose at the reduced pressure, but then meets another slow down point (the built in reducer) its going to decrease the flow even if its the same pressure. Any angle or elbow in a pipe will slow down water flow so a second pressure reducer valve will do the same. I'm not a plumber but I've seen evidence of this in some of my pond building projects.
I hope to hear back from the FB owner with this issue. The good news is, many owners of earlier trailers understand the importance of the pressure regulator. The bad news is that an owner of a new trailer unfamiliar with the new setup might get bad advice from well meaning people.
Yes, you only need one water pressure regulator in the line, and adding more units may reduce the water flow, even if the pressure is not changed significantly, due to adding more resistance to the water flow. I carry a spare, these things do fail, and I have one with a pressure gauge so I can see the reduction.
That said, a flow reducer and a pressure regulator are tow different devices, with the flow reducer limiting the water flow, but not necessarily the pressure. A pressure regulator limits the water pressure to match its setting, like taking a 65 psi source and reducing the pressure to 45 psi, but water flow is not significantly reduced (although some reduction does occur).
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
So I wanted to get my eyeballs on the built in pressure regulator. I identified the city water inlet and I don't see anything on that or anywhere else that looks like a pressure regulator. Anyone got a pic of it on a 2022 400? I thought I saw one here somewhere but I can't find it now.
My T@B is at my son's, but if you follow the line it is a white plastic device, about 3" long, I want to say about 14"-18" from the actual city inlet fitting.
On our previous campers the water pressure regulator was built into the city inlet fitting. Just past the inlet fitting would be a separate plastic anti-reverse flow valve, which I think is required on late model campers.
Doug K
Douglas and Cheryl both Navy Retired 2022 Tab 320s Boondock/2021 Honda Ridgeline BE Minnesota and Arizona
I took the above picture. We have a 2022 Tab 320S. The location on a 400 may vary, but I would assume the pressure regulator itself, may look very similar.
Scott / 2019 T@B 400 "C@lypso" / 2015 Chevrolet Tahoe LTZ / Northern Illinois
Yes I was looking behind the nautilus where the city water comes in but I don't see anything white like that or that shape. Now that I have a pic though I will go back out tomorrow and look again.
We picked up our 320 this week. It does not have the water pressure regulator built in. They included one in the welcome package. The dealer, who is pretty in tune to NuCamp said they were having problems with this change so they've gone back to the old procedure of giving a regulator to be used at the campsite pedestal. I was concerned about them making it part of the plumbing because if it failed that creates a big plumbing repair job. Much prefer to attach it to the pedestal.
We have a 2022 Tab 320S. NuCamps comments have me a little concerned. I will have to keep an eye on the built-in pressure regular... except it may be difficult to determine when/if it fails since it is buried under the seat. I will be interested to learn what others are doing.
Thanks TabbyShack for the reply. I was hoping a failure would result in no flow into the Tab. I may want to have a backup pressure regulator we us, just in case.
Well I guess it depends a bit on how it fails too. If it were to crack then I guess that would cause water to leak inside T@B. I guess we need to find out what was happening with the ones that failed.
Not sure if this is correct thinking or not since I haven't used my T@B yet but I did buy an external variable water pressure regulator to be used in tandem with the one Nucamp included (assuming I have one included). I will play around with this combination to see how it behaves.
2022 T@B 320S Boondock 2021 Toyota RAV4 TRD Off Road Ottawa, Ontario, Canada Instagram: new.t@bventure
South Jersey
Odessa, Fl.
I am looking for a recent thread regarding an issue with the pressure regulator.
South Jersey
South Jersey
Doug K
Thanks for the pic!!
Scott you will know if it fails because the pressure blows open the yellow flappers valves and water will drain under camper.
