The first thing I've done on my last two T@Bs is to switch out the clunky droopy safety chains for cables. They are lighter and easier to handle and don't hang way down under the tongue.
Amazon.com: CURT 80151 44-1/2-Inch Vinyl-Coated Trailer Safety Cables, 7/16-In Snap Hooks, 5,000 lbs Break Strength, 2-Pack : Automotive
Oneonta, NY
I'm going out for maiden voyage Friday. I will get a pic of the set up on a 400.
These chains seem perfectly acceptable, based on the Famous Purdue "Keep Trailer Attached" booklet. (Chain discussion on page 42 below, with more discussion in the "Emergency Brake" chapter that follows.
The chains on my 2017 320 are 30 inches long. Are the chains on the 400 longer?
https://www.extension.purdue.edu/extmedia/ppp/ppp-92.pdf
Brad
Concord, NC
2017 Highlander Limited
ChanW said: The chains do not come welded to the frame on the past three T@Bs I've owned.
However climbers weigh a lot less than the trailer so I don’t know if it would work
Are the chains attached with the same round "washers" or is that something my dealer added? That's the point if failure. Those washers have to carry around 350lbs if needed.
"Grade 8" but exactly what "width" they are is hard to tell. They do seem slightly "warped". (slightly). Whether from the original installation or stressed from 5 years on the road, it is hard to tell.
Odessa, Fl.
