I was just told (third hand from a friend with one on order) that NuCamp has discontinued the 3 way fridge. I don't have any other details. It could be supply issues, but maybe its because the 3 way can't keep up on propane when the temps are really hot outside? I think I saw this complaint here on the forum and my friend said the same thing. I've not tried this personally.
I'm wondering are you still going to have a big fridge/little fridge option but both will be 2 way?
1 ·
2019 320 Boondock Edge - Sold Jan 2022
Southern California
Full-timer since 2019
NorCold did stop production on the original N3104 3-way however their web-site continues to show the N4104 3-way (recently used by nüCamp in 400's) as available in different size options.
1. For most TaBers who use full hookup sites, a two way gives them more space in the fridge than a three way in the same footprint.
2. Compressor fridges hold temp control in the f ridge much better and use.
3. You do not have big vent holes in the side of your RV.
4. It uses less DC power/energy running on 12VDC than a two-way
However, that does not address your statement/belief that
NorCold has discontinued 3-Way N4104 (or similar size) production.
So do you have a source other than this forum to state NorCold has discontinued smaller 3-ways?
I'm not trying to be difficult . . . am just interested in how the RV refrigeration options are evolving.
I posted this on April 24. It's my direct communication from nuCamp re the switch to the new 2-way fridge:
Thank you for being a part of the nuCamp family.
2022 F-150
Gratitude
2022 F-150
Gratitude
Specs state average 418 watt average/24 hours based on 41 degree refir setpoint and 77 degree ambient temperature. The compressor draw is 4.7 to 5.0 amps at 12VDC. Continuous run time in 24 hours would be 1354 to1440 watt hours. So based on average daily 418 watt hours the compressor will run 29 to 30 percent of the time.
Sharon, Internet listings are often out of date, and what appears to be available, is actual not when you go to order it, especially from retail dealer listings.
