Water for toilet flushing
Buckster
Member Posts: 62
We’re camping and our toilet has been operating fine. But all of a sudden it has stopped swirling water. Our fresh water tank is 2/3 full. We’re new to the 320, so any recommendations on how to troubleshoot would be appreciated.
2022 T@B 320 CS-S Boondock
2018 Nissan Frontier 4x4
SW Ohio
SW Ohio
@Buckster, when you say the toilet "has stopped swirling water," do you mean that no water is entering the toilet bowl when you pull on the flush handle? Is there any flow of water, even if just minimal?
Does water come out of the kitchen sink when you open the water valve? Assuming it is, then the pump is working and the issue is not likely due to a problem with the pump or a blown fuse, but do you hear the water pump cycling (or attempting to cycle) when you pull on the toilet flush handle?
Also, just to be clear, since you say that the fresh water tank is 2/3 full, is it correct to assume that you are relying on water from the fresh water tank and not connected to a campground or other water spigot as your water source?2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Is pump on and keeping pressure? Our 2021 320s has air leak but not water leak at more than one pex compression fitting. We have to reprime pump intermittently. Water bottle and short 3/4 inch hose to the manifold Sanitize fitting. Pump water in. Shut pump switch back to boondock mode, cycle pump until pressurized. A real nuisance once or several times a day when on the road.
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck -
Thanks for the responses. I’ll ask a silly follow-up question? Does the water pump need to be on for the water to come out and swirl around the bowl? I turned the pump on this morning and everything worked flawlessly. We had been attempting to “flush” in the middle of the night without first turning on the pump. Could that have caused the issue?2022 T@B 320 CS-S Boondock
SW Ohio -
Yes. When you boondock you need to turn on the pump to use any water. Remember to turn off the pump if you leave your campsite.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
A home toilet, and some cassette toilets have a reservoir with water in them to flush the toilet. However, the TaBs and most RVs have toilets that are directly connected to the trailer’s water system to flush the waste. So when not connected to City water, you need to have the water pump on to flush the toilet.
A water pump switch in the washroom would be nice to allow turning the pump on and off at nighttime.Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
By the way... turning on your pump, letting it run until it shuts itself off, then shutting off the pump switch leaves enough pressure in the water system for quite a few "flushes" - likely enough to get through a few night time uses without cycling on that noisy pump. The "on-suite" bedroom isn't really that far from the bathroom, noise-wise...Yanni Lazarus 2020 T@B320S, 2018 RAV4 Adventure, Central CT
Alternatively, if the pump is likely to wake a sleeping partner, leave it switched off & keep a gallon jug of water in the bathroom. Open the valve & use the jug to rinse down the contents. (Many do the same thing using RV antifreeze during winterized camping.)2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
Our 2021 Tab320 was fine last fall, but water pump keeps losing its prime this spring. Air in line prevents it from pulling water from tank. We have to reprime the pump to use the sink or toilet during any stop. (Set nautilus valves to Sanitize, pump in a pint of water from a water bottle & hose we started keeping in the compartment, quickly switch over to Boondock and run pump to 40 psi shutoff.)
Suspecting the nautilus check valve, we bought a replacement from the Nautilus website listed reseller (pic, model and serial number provided), only to find the version on our camper simply cannot be replaced. A big job to replace the entire panel- we opted out. Inspected existing check valve and determined it works fine.
Maintains pressure for days while parked. Once on the road would very quickly lose it.
Once home conducted a more thorough 5psi air and listening test and determined at least one connection to Nautilus was suspect.
We also see a number of improperly installed pex clamps- too close or too far from fitting.
Can't just cut them off and refit, you have to splice the pex or replace it. Hoping this will not be necessary.
If we determine the pex installation is admitting air this may become a contentious post-warranty claim.
Inspected and gently tightened every threaded nylon connection to nautilus and water pump.
After two bumpy rides around the neighborhood it's sofar holding pressure. We're holding our breath...
@Maxcamp8 *sorry misread your initial post. Edited to say I doubt most problems with nüCamp are or will be contentious.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
- 916 Introductions
- 72 Teardrop Groups & Links
