Hi all,
I recently bought a 2020 320s and the dealer said he put in a brand new battery, which sounded good.
Now, I was researching batteries and other stuff, so I decided to go out and check what kind of battery is actually in there.
It's
this Napa battery, model 8240.
It's called a dual purpose battery and in the product description it says:
"Dual Purpose Battery For Excellent Starting & Moderate Deep Cycle Service... Dual purpose power ideal for larger, harder starting engines and/or moderate-duty trolling or accessory loads... Vibration resistant design protects battery against demanding marine use."
The specs list cranking amperage and cold cranking amperage... things to look for in a good car battery/ maybe a boat battery.
But is that the appropriate battery? I feel like this is not correct for a trailer (I will certainly not use it to start any engines).
Trying to figure out if I should call and complain and ask that they give me a different, more appropriate battery, that specifies amp hours.
What do you think? In any case, I need to get something different than this, since I will be mostly doing dry camping and I will need some amp hours and this battery does not even have specs for that.
Thanks!
2020 T@B 320s Boondock Lite. 2015 Kia Sorrento EX V6 AWD
best battery to get, a Deep Cycle RV house battery should have been what the dealer installed.
Sounds like they went for the least cost battery. I would ask that they replace it, and offer to pay the difference for a deep cycle lead acid battery they should have installed, and upgrade to a 100 AmpHr AGM battery, which is a better choice yet. Next would be to upgrade to a 100 AmpHr, Lithium, but that is twice the cost of an AGM.
. . . cheapest 'deep cycle' rated battery available.
How long "it lasts" will be a function of your camping style.
Most owners seem to replace 'the dealer' battery within two years.
Sold 2023 Tab 400
Sold 2018 T@B 320S
@newcamp I can pretty much guarantee they’ll tell you it’s the standard battery they provide for this size trailer, but it doesn’t hurt to ask. Yes, you’ll probably need something better for boondocking, but get out and try it a couple of times first. It’s a good battery to driveway camp with while getting to know your systems and figuring out what you actually need in the way of battery/solar/charging options.
I was thinking about adding a second one, not lithium, but something like a $250 Renogy deep cycle and just add it parallel to this existing one. That way at least they can compliment each other and I can worry less about draining.
I might call and ask in a friendly manner if they would consider giving me something different instead and at the very least trade it in for a better one.
Anyone else, feel free to correct me on this thought process.
Tell them to swap out for correct deep cycle battery.
Please folks…. Stop accepting shoddy products from your dealers. Incomplete trailers, no screen doors missing blinds, missing Yakima racks. It’s beginning to give our trailers a bad reputation.
Odessa, Fl.
It's a 40 min drive to the dealer, so I'm not sure about driving there just to have it replaced (and possibly pay for difference). Considering if I would keep the Napa battery as a "backup", keeping it inside my TV. Then put in a 100 ah battery instead of this in the tongue box.
Going dry camping for two nights in a couple of weeks. If I keep the Napa in there we will see how it holds up. I feel like it would drain pretty fast and become useless after a few trips like that. I could get a solar panel to keep it topped off, but I will be in the forest so sunspots will be sparse.
Thanks for all the input! Definitely good to know I cannot mix battery types.
Edit: 120 minutes reserve capacity translates to 50AH
Sorry for the nitpicking.
That said, I 1000% agree with @bergger, and have for years. Especially now that interior battery placement is an option they discussed in the sales video for the 2021? Just wire it that way straight from the factory and be done with it. They do themselves no favors allowing the dealer to put a cheap 50ah battery on their trailer.
Whilst most deep cycle AGM Marine batteries are 200AH and up, you can buy a 100 amp deep cycle AGM battery, here is a Duracell Group 27 ( most Group 24s are wet cell or dual purpose batteries) 12VDC 92AH deep cycle marine/RV battery. Most marine deep cycle batteries can crank an engine, but not their main purpose and have a CCA rating, but they are mainly intended as house batteries. AGroup 27 should fit in the front tub, but will need a bigger bracket.
https://www.batteriesplus.com/productdetails/SLI27MAGMDC?source=bing&medium=shopping&campaign=ecommpla&msclkid=80acb282b3351ec21be4d006c0f96b67&utm_source=bing&utm_medium=cpc&utm_campaign=%5BADL%5D%20%5BPLA%5D%20Shopping%20-%20All%20Online&utm_term=4579740809732222&utm_content=%5BADL%5D%20%5BPLA%5D%20Shopping%20-%20Product%20Type
Yes some so called AGMs are not what they claim to be, seen this too.
I will edit my previous post. Thanks agin.
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Odessa, Fl.
