If you were to go with an external smart charger for topping off batteries with a generator, what characteristics would it have? While boondocking many days in shady conditions I have to resort to running the generator. The WFCO convertor never achieves bulk mode for various reasons discussed in other posts and will only deliver 13.6v no matter the state of discharge of the battery. I'm hoping to deliver up to 14.6v for deeper charging in less time with an external charger. I currently have the WFCO8735, which delivers up to 35amp. I am charging AGM's and am not interested in upgrading the converter at this time.
DavidW - Asheville, NC
2021 320s Boondock/2017 4Runner
0 ·
You don't say which model you have, but the best bet for the money would be to fix the resistance of the 8-gauge wiring by either using 6-gauge or add an additional 8-gauge circuit for both the positive and negative wires. By reducing the resistance, the charging properties will be much better.
I have a complete different set up than what was factory but can easily get 60 to 70 Amps to my batteries with the solar and converter.
Brad
Concord, NC
All converters work in a similar fashion, determining the amperage rate based on the battery voltage (IE state of charge). The problem encountered with most all RV's is the gauge of wiring used between the Power Distribution Center (aka PDC) and the battery when combined with the distance it is run. On startup of the converter, SOC is determined by measuring voltage and how quickly it rises, if the voltage rises very quickly (such is caused by too small of wiring) it switches immediately to the Absorption Mode. Absorption Mode will take 24 to 36 hours to charge a small battery bank.
If you are using AGM or Standard Lead Acid Batteries, the maximum charging rate is 15% to 20% of the total battery capacity depending on actual chemistry and Battery OEM Guidelines. IE, a 200 Amp Battery Bank could accept up to 40 Amps (again depending on actual battery chemistry and battery manufacturer guidelines), but I would probably stick with the 35 Amps you have.
Lithium batteries can take up to 50% of the total battery capacity. IE, in my case I have 400 Ah of Battleborn and could charge at up to 200 Amps. There are many reason that I don't use 200 Amps, which I will leave out of this discussion.
In the case of Progressive Dynamics and their "Charge Wizard" technology for non-lithium batteries, the voltages are as follows:
Bulk (Boost) Mode 14.4 Volts
Absorption Mode 13.6 Volts
Storage Mode 13.2 Volts
Storage is activated if there isn't any significant battery discharge in 30 hours. This prevents boiling of the electrolyte in the battery and ultimately damaging the battery bank.
In my case, I removed the converter from the Power Distribution Center and installed a self-contained PD9160ALV within 12 inches of the battery junction block under the bed. I used 4-gauge battery cables to make the connection. My battery Bank is connected to this junction block with 2/0-gauge cables. This was a much easier to install solution since I needed to change the converter to a unit for Lithium Batteries anyway. It prevented me from having to run approximately 50 foot of additional wiring through some areas that are not easily accessible. I used very large cables to reduce this resistance along with the fact that 2/0-gauge is marginal if I were to pull the entre capability of the battery bank at once (800 Amps for 30 seconds). Since my highest draw is my inverter using a toaster at 90 Amps or less, 2/0 is more than enough.
Again, I am not sure exactly what you have, batteries, or year, other than it is a 320.
Bottom line becomes this, how much do you want to spend and are you able to do the work yourself? If you install a converter outside of the OEM, you will want to remove the original in the Power Distribution Center. It has 5 wires to disconnect and 2 screws to remove.
Note: 14.6 is too high for non-lithium batteries to be charged at safely.
Brad
Concord, NC
@Dutch061, what would be contraindicated with using a 120v source smart charger clamped direct to battery terminals?
We did this after five days boondocking in no services provincial park in the shade.
I was uncertain about charging the two parallel 100ah Battleborn LiPoFes together so pulled all the 30a inline fuses from interconnecting wires and charged one at a time using generator. Did this during the day while we were out or not needing trailer systems.
Made sure to balance charges at next park on shore power.
Not something we'd want to do regularly but then we had not run down to 48 percent SOC ever before.
In my answer(s), I related what the problem is and how to correct it. I am fairly well versed in this, having gone through all of it already.
Yes, it is possible to carry an external charger with you, but the majority of those that are "consumer grade" and truly portable will only deliver 2 to 10 amps anyway. So, if that is the case, what did you actually gain? Why not fix the resistance problem and have 35 amps available in the "bulk mode"?
The batteries may be easily accessed on 320's but certainly not so much on 400's. I realize the OP has a 320 and the battery is likely still in the tub which would make connection simple.
Brad
Concord, NC
Seattle, WA
I would like to leave the WFCO as a 12 volt power supply and distribution center and have the smart charger handle the battery charging only. The only confusing part of this for me is how to isolate the battery when charging but have the battery provide the 12 volt power to the WFCO when not on 120 volt power.
Seems like the solution would be to have a 120 volt solenoid to isolate the battery from the WFCO when 120 volt power is applied but upon loss of 120 volt power connect the battery to the WFCO for 12 volt power distribution. You could do this manually but a solenoid as I described would automate the switching.
Am I making this too complicated?
Seattle, WA
2022 T@b 320 S / 2021 Subaru Outback
Then I'll keep the shore power plugged in to run anything as I need it. I'll keep the Tab powered up, keeping the tracker battery charged, etc.
Thus the Tab is on shore power, and the battery is isolated on the smart-charger. I'd rather not confuse the smart-charger's algorithm by having two charging sources connected at once.
managed by VE Smart Network
From the Victron MPPT Manual, (see attached PDF Page 7 at the top)
Brad
Concord, NC
I found a normally closed 120 volt relay that I may install to automatically disconnect the battery upon 120 volt so I don't have to manually disconnect the battery. The relay is less than $20 but for now I will disconnect it manually.
Also, the Genius5 say, "Battery Capacity: Up to 120Ah, Maintains All Battery Sizes". Does that mean it won't even work with two 125Ah batteries wired in parallel? Don't understand the difference between "capacity" and "maintains".
"How much muscle does your portable generator need to run a high-output battery charger? Simply speaking, a 300-watt generator can handle most 10-amp chargers; step up to a 600-watt generator to power a 30-amp charger. What about coupling a portable generator with your RV’s existing battery converter? Unless you’ve got one of the sophisticated converter-chargers mentioned earlier, the output from the converter is so low as to be almost useless."
