This past weekend, when on a trip I noticed the trim on our 400 coming loose in a few areas.  It is the trim that covers the seams where the side walls and roof join together.  It is coming loose where the trim pieces join together. It was very obvious in one area so I looked at the rest of the trim and found more coming loose.   One piece also has a crack in it.  When pushed back down behind the keder rail it of course just pops back up out of place.  There are oval holes in the trim part that tucks behind the keder rail that appear to have the bottom portion missing.  Others do not have that part missing.  I assume that those holes are where screws attach it to the trailer??  However I am not certain about that as I can not see behind the keder rail to find out exactly what is holding the trim on.
I contacted NuCamp Warranty and was advised that the issue is out of the one year warranty and not covered under the three year structural warranty.  However they said they would send me 5 pieces of trim at no charge.  I have asked them how I am supposed to remove the old trim and install the new trim but have not heard back yet.  I also have yet to contact the closest dealer to me about this as I am waiting to get more info from NuCamp.  In the meantime does anyone know how the trim is attached and how to do this?  Just looking at it it does not appear to be an easy job.  But if nothing is done the trim will continue to loosen and I'm sure will eventually come off while traveling.  It is a bit disappointing after 2 1/2 years of use with only about 4500 miles of travel.
The red arrows show the trim pieces that are coming loose and or have cracks and the green arrows show the areas of the trim that are coming loose.
Here is the worst part and what I initially noticed while camping.
Here is behind that the area pictured above.
Here is a crack and loose area on the drivers side of the trailer.
Any others with experience in this area and how to replace or repair it?
2020 Tacoma TRD Off-Road
2008 Toyota Sequoia 5.7 L
If they used 3M tape and had the trim manufactured where the joints actually attached to each other and reinforced the locations where the screws attach it I think it'd be just fine. As it is, you really need to keep an eye on it and as soon as you see it start to pop up you need to tighten it back down.
You can see in the picture poste by @85Redwood where the problem starts. The oval holes where the screws go through break. They should be oval holes and not cutouts as seen in his photo. Once the bottom of the oval hole breaks off the trim works itself up and out from behind the keder rail due to vibration. The screw no longer holds it on it's just held on from the pressure of the keder rail. Then if not noticed and corrected the wind can catch it and rip it off. That's why I drilled some small pilot holes and added a few extra screws. The holes I drilled in the trim are much smaller than the factory ones and I believe less likely to crack and break. But only time will tell.
When the trim was still on and I was sitting beside the camper as the morning sun was getting stronger the trim was audibly creaking as it warmed up...my hypothesis is that in addition to brittleness it expands when heated which leads to stress cracking.
I can replace it with the same material but the definition of insanity comes to mind.
Anyone have an idea for a decent, nice-looking alternative (i.e., not eternabond 😒)?
I just recently removed the plastic trim and partially detached the keder rail on my 2019 320 S Boondock Lite to resecure the rubber flap seal. In that process, I discovered that there are a few screws that secure the plastic trim to the trailer wall, which are concealed under the keder rail. You likely won't see those trim screws (at least completely) unless you first detach the keder rail.
Before detaching the plastic trim, I marked those few screws with green painter's tape (see second photo) so it was clear where I needed to reattach the screws and secure the plastic trim. The photo is a good depiction of how the plastic trim screw is concealed under the keder rail (which itself is held in place by several more screws.)
The third photo shows a closeup of the black trim and two holes (to secure the black trim) marked with the green painter's tape. All the remaining screw holes are for attaching and securing the keder rail over the plastic trim.
Removing and reattaching the black trim and keder rail was an easy process and did not really require much time or effort. It will help to add some caulk to the screw thread before reinserting them to prevent water intrusion in those areas. Similarly, put a small bit of caulk in any original holes that will no longer be used.
I just uncovered the trailer today from winter storage and checked every exterior screw I had access to all over the trailer. It's a good thing to do every spring. The trim screws I tightened last summer when I encountered this issue were still tight for the most part. A couple just slightly loose.
2024 T@g 5-wide Black Canyon
Have several places around the hard plastic trim where the trim that holds the screws completely broken off so I also need to remove keder rail, all trim, redrill holes next to broken holes and replace screws,caulk, blah blah blah. Everywhere--along the roof line front to back, wheel well plastic trim, etc am starting to see this in spots. Plus have some news cracks in trim on roof from hail damage.
Anyone know if there is a black self leveling caulk or something to use to cover up a crack to prevent water intrusion on this plastic? One of the cracks from hail is going to require caulk or entire replacement of the shroud across the entire back of the trailer, but the crack is small and I'm not up to that project or the cost.
Am also very disappointed that I am now looking at this being an ongoing issue going forward. Live in Colorado where we get high temps in summer and well below freezing for weeks on end in winter and even though I cover trailer during the winter it can't stop the temp fluctuations.
Poor choice of trim material, period, Nucamp, yet they still continue to use it and surely they have had plenty of feedback by now??
Any clues to procedure would be helpful. Pry upwards? outwards? I know there are clips.
Do not see any visible screws in black half round trim or in Kedar Rail until is removed.
