Let me first apologize if this is not the correct sub-forum for this narrative and question. Edit: Probably should be in "Trailer and Towing." My bad and hopefully a moderator will move if needed.
As I was towing the camper to it's storage lot, a short trip I've taken many times before, our 320S BD came loose from the TV. The location of the incident was just after a traffic light at the intersection of a local, neighborhood road and a busy 4-lane county road. From my direction, there is a very slight incline on the neighborhood street, just before the county road. I waited here for the light to change and was turning left onto the larger road when I heard a bump, then louder thud, and finally the sound of metal being dragged on asphalt. Thankfully, I had cleared the intersection and was in the far right of the undivided, 4-lane county road when everything came to rest, blocking only one lane. Even more thankfully, I was able to crank up the T@b up enough to get the ball under the coupler in short order and get on my way.
I'm guessing that I had not cranked the tongue jack up fully, and it hit the pavement as I was cresting the small hill while turning left at the intersection (the bump I felt). That in turn pushed the tongue up and off the ball, after which the camper dropped (the thud) to the pavement. After reconnecting everything, I returned to the house to examine things before attempting even the short journey to the storage yard. Let me note that the coupler was locked to the ball, with the safety pin in place when this happened. When I returned home after re-hitching everything, I tested the coupler-ball connection. With the camper still hitched to the TV, I used a hydraulic floor jack to lift the tongue to the point that it was in turn lifting the back of the TV. The connection held just fine. After this check, I then towed the camper to storage yard without further incident.
The damage is minimal, and pretty much limited to a slight deformation and scuffing of the base of the tube of the tongue jack. This made it impossible to attach the adapter with the wheel to the tube, but this was fixed by filing the scraped area flush with the tube, along with some help from a large cast-iron C-clamp to re-round the tube bottom.
The more lasting damage is to my psyche: I'm now paranoid about towing, thinking that every little bump and dip will cause a repeat situation. I surely can't be the first to have this kind of thing happen, and wonder what others who've been in the same boat have to say about the experience. I also wonder if my supposition about the root cause (the tongue jack tube not being fully up) is likely correct.
It looked like this...
Are there signs that the coupler was bent, or temporarily flexed, by bouncing and dragged on the pavement?
Some ideas:
- Maybe the ball socket section of the coupler flexed up as the more rigid front of the A-frame flexed down during the dragging?
2020 Tacoma TRD Off-Road
NuCamp bolts the chains to the trailer. Next time you hook up, connect the chains. Remove the bolts and adjust the chain length with a couple inches of slack while straight. Don't cut off the extra. I used safety wire to tie the spare links together.
"Just Enough"
"Just Enough"
I disagree with this. If your coupler separates from the ball, you still have the chains to keep the trailer behind you and your trailer brake will still work for a good chance of a safely stopping. But if the trailer brakes were to lock up due to the pin being pulled while still attached by the chains your chances of maintaining control is greatly reduced. In my opinion the emergency braking system should not engage unless there's been a complete (ball, chains and electric) separation of the trailer from the tow vehicle. I believe the sole reason is to prevent a runaway trailer from causing collateral damage.
We've had 3 breakaways make the news here in upstate NY this week and all three destroyed the trailers and one the TV as well. I'll bet the farm all three of them had the breakaways set up like you want it or else didn't even have one. According to police reports none of the three disconnected from the safety chains. So much for bringing the trailer to a safe stop using the brake controller."
Section 393.70(d) requires that every full trailer must be coupled to the frame, or an extension of the frame, of the motor vehicle which tows it with one or more safety devices to prevent the towed vehicle from breaking loose in the event the tow-bar fails or becomes disconnected. The safety device must be connected to the towed and towing vehicles and to the tow-bar in a manner which prevents the tow-bar from dropping to the ground in the event it fails or becomes disconnected.
It goes on to explain the reason is to prevent the trailer from asperating and causing additional damage to other cars and property.
"Just Enough"
"Just Enough"
