Has anyone replaced their Alde mixing valve?
After getting a service appointment 3 weeks away and being told that would just get me in line for diagnosis.
I have been in touch with the NuCamp techs, and it appears to be t
consensus the mixing valve is not working.
I ordered the valve thru my dealer and should have it next week. I am a former A/C and Heating mechanic and feel I can do the replacement myself.
                0 ·
Longer answer. I do not recall any mixing valve specific DIY Install/Repair discussions. From time to time there is a brief comment within a longer hot water discussion as to an owner doing the work.
Also note, there are two types/brands of the mixing valve. The one you receive from nüCamp might not be identical to the one installed . . . . which shouldn't change the installation but might add some complications.
With your former life technical background the change out should be well within your skill set . . .
provided you have the tools and your new life body can access the valve location . . .
2020 Tacoma TRD Off-Road
I immediately suspected the Alde TMV.
Upon removal from the system (quite easy) I could see the filter screen on the inlet side was nearly completely clogged. I tried cleaning without removal but the material covering the screen did not seem to move. I removed the screen from the valve and found I needed to use LimeAway to dissolve the deposits. This is a very fine screen. Much finer than the typical aerator screens.
When reassembled and reinstalled the hot water flow was as new.
If I have to do this again, I will probably just remove the screen. There are no critical sealing surfaces in the valve and it doesn't appear to need this protection in a relatively clean system. I'm sure this screen is the cause of the reduced flow on the hot water side even when in perfect condition.
The screen was not that difficult to remove if your familiar with snap clips in a groove. The deposits on mine would not move even with brushing and scraping. Like rhyno they were only present on the HOT inlet side of the valve. The LimeAway or vinegar type cleaning was necessary. You could see the foaming reaction. We live on a hard water well and I have seen this before many times.
I too had the low hot water output last year. My dealer cleaned the gunk from the screen in the mixing valve this spring and all is well, at least for now.
Sold 2023 Tab 400
Sold 2018 T@B 320S
Parts List would say No Filter Screen in the older style . . .
