Changed out the stock faucet
2»
    qhumberd Administrator, Moderator Posts: 912
    ChrisFix said:
    @qhumberd
    You'll also need to adapt the water supply lines provided with the faucet to the 1/2" water fittings from the T@B.
    This or something like it should do the trick:
    https://www.amazon.com/Faucet-Adapter-WEWE-Fittings-Connector/dp/B08VRPYWLM?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A3HDYWGVCBF05F
    Finally got around to changing the stock faucet in our 2019 400. I have to amplify and thank all for this mod. I think this is the most functional change we have made since we got the trailer. My original faucet was on pretty tight, and even with just a plastic nut it was hard to reach, but with some work it came out.
    The install of this new faucet, with the adapters from @ChrisFix made the job very easy. It all folds and fits beneath the glass cover no problem. As cheap as this replacement is, I wonder why they don't make it standard?
    Thanks all!!
  • californication
    californication Member Posts: 50
    elbolillo said:
    I’m in a 2020 320s Boondock Edge.  Any suggestions?
    This is the faucet we used for our '21 Tab 320:
    https://www.amazon.com/gp/product/B092YSBW7X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
    This was a huge improvement over the stock faucet.
    I just installed this faucet! My wife couldn't be more happier! The change over the stock one is amazing!
    Thank you!
    Tab 320s Boondock 2022 | Jeep JKU 2017
    Mods: MaxxAir 7500S | 2x 100Ah LiFePo4 | Victron MPPT 75/15 | Ultimate Trailer Jack
  • Blueespy
    Blueespy Member Posts: 288
    elbolillo said:
    Swapped out the standard faucet in our '23 Tab 400. This new faucet provides so much more room for larger items under the faucet and has a nice adjustable stream.
    Awesome.  Can you provide photos of the hose hookup under the cabinet.  I’m guessing you had to change out the hot/cold hoses nuCamp had. Thank you
    Haven 220
    2026 Ford F150 Tremor 5.0
    Niceville, Florida
  • marchule
    marchule Member Posts: 47
    Hope these photos help.
    2018 320S / KIA Sorento 3.5 V6  - 2022 400 Boondock / KIA Telluride 3.8 V6  -  Utah
  • elbolillo
    elbolillo Member Posts: 575
    @Blueespy
    Here is a photo. I only needed to add the adapter from the faucet lines to attach to the original connectors.
  • andytabrv
    andytabrv Member Posts: 55
    @elbolillo thank you so much for the post and pics.  I swapped mine out this weekend.  Faucet install was super easy and is sooooo much more functional.  I forgot to also order the adapters so I'm awaiting them in the mail today to finish it.  I was expecting it to be much more difficult to swap, but that was very simple.
    2022 Nissan Pathfinder
    Cary, North Carolina
  • Kevin_K
    Kevin_K Member Posts: 38
    Upgraded mine also due to a review on Amazon stating that they purchased it for a Tab 400. Great fit!
    2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk
    I am reviving this thread as it appears this faucet is no longer available at least with Amazon. Also, though we love ours, the upright seems to have gotten loose and wants to fall forward now. Anyone se a way to tight up the up and down rotation?
  • EPOD1
    EPOD1 Member Posts: 42
    I went through this once already and found the "one that fits" is actually poorly made and I still had that shallow sink and glass top to deal with.
    I am not the first to know the joy of a real sink and faucet in my trailer.
    FIG9.jpg 664.7K
  • MountainMade
    MountainMade Member Posts: 11
    edited October 3
    That looks great! 🙌 It must have been a bear to work in the small space where you added the faucet!
    I added a new faucet last month but I haven’t changed the sink out so the fix is not quite there yet.
    I will eventually install a different sink.
    Could you send a link for your sink?
    Wander Yonder….
    🌻 Denise
    🐾 Bella
    Home Base: Kamas, Utah
    TV: 2018 4Runner Limited
    TT: 2020 T@b 400 Boondock Lite—(previously 2020 320s Boondock Edge)
    @EPOD1 Thanks for that:
    The deeper sink is a bit more than I want to tackle at present, though I see the very real benefit. A deep sink with a cutting board cutter and a pull down faucet like you have looks ideal.
    Thanks
  • MOS2
    MOS2 Member Posts: 62
    I like the cutting board . Where did you get it ?
  • MOS2
  • EPOD1
    Link to the sink:
    Dawn Sink
    Link to my install:
    Replace Sink/faucet
    Honestly, it was pretty easy.
    And Everyone loves it now, it actually a real sink.
