Changed out the stock faucet
2»
  • ChrisFix said:
    @qhumberd
    You'll also need to adapt the water supply lines provided with the faucet to the 1/2" water fittings from the T@B.
    This or something like it should do the trick:
    https://www.amazon.com/Faucet-Adapter-WEWE-Fittings-Connector/dp/B08VRPYWLM?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A3HDYWGVCBF05F
    Finally got around to changing the stock faucet in our 2019 400. I have to amplify and thank all for this mod. I think this is the most functional change we have made since we got the trailer. My original faucet was on pretty tight, and even with just a plastic nut it was hard to reach, but with some work it came out.
    The install of this new faucet, with the adapters from @ChrisFix made the job very easy. It all folds and fits beneath the glass cover no problem. As cheap as this replacement is, I wonder why they don't make it standard?
    Thanks all!!
  • elbolillo said:
    I’m in a 2020 320s Boondock Edge.  Any suggestions?
    This is the faucet we used for our '21 Tab 320:
    https://www.amazon.com/gp/product/B092YSBW7X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
    This was a huge improvement over the stock faucet.
    I just installed this faucet! My wife couldn't be more happier! The change over the stock one is amazing!
    Thank you!
    Tab 320s Boondock 2022 | Jeep JKU 2017
    Mods: MaxxAir 7500S | 2x 100Ah LiFePo4 | Victron MPPT 75/15 | Ultimate Trailer Jack
  • elbolillo said:
    Swapped out the standard faucet in our '23 Tab 400. This new faucet provides so much more room for larger items under the faucet and has a nice adjustable stream.
    Awesome.  Can you provide photos of the hose hookup under the cabinet.  I’m guessing you had to change out the hot/cold hoses nuCamp had. Thank you
    Haven 220
    2026 Ford F150 Tremor 5.0
    Niceville, Florida
  • Hope these photos help.
    2018 320S / KIA Sorento 3.5 V6  - 2022 400 Boondock / KIA Telluride 3.8 V6  -  Utah
  • @Blueespy
    Here is a photo. I only needed to add the adapter from the faucet lines to attach to the original connectors.
  • @elbolillo thank you so much for the post and pics.  I swapped mine out this weekend.  Faucet install was super easy and is sooooo much more functional.  I forgot to also order the adapters so I'm awaiting them in the mail today to finish it.  I was expecting it to be much more difficult to swap, but that was very simple.
    2022 Nissan Pathfinder
    Cary, North Carolina
  • Upgraded mine also due to a review on Amazon stating that they purchased it for a Tab 400. Great fit!
    2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk
