Changed out the stock faucet
Finally got around to changing the stock faucet in our 2019 400. I have to amplify and thank all for this mod. I think this is the most functional change we have made since we got the trailer. My original faucet was on pretty tight, and even with just a plastic nut it was hard to reach, but with some work it came out.ChrisFix said:@qhumberd
You'll also need to adapt the water supply lines provided with the faucet to the 1/2" water fittings from the T@B.
This or something like it should do the trick:
https://www.amazon.com/Faucet-Adapter-WEWE-Fittings-Connector/dp/B08VRPYWLM?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A3HDYWGVCBF05F
The install of this new faucet, with the adapters from @ChrisFix made the job very easy. It all folds and fits beneath the glass cover no problem. As cheap as this replacement is, I wonder why they don't make it standard?
Thanks all!!2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
elbolillo said:
This is the faucet we used for our '21 Tab 320:MountainMade said:I’m in a 2020 320s Boondock Edge. Any suggestions?
https://www.amazon.com/gp/product/B092YSBW7X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
This was a huge improvement over the stock faucet.
I just installed this faucet! My wife couldn't be more happier! The change over the stock one is amazing!
Thank you!
Tab 320s Boondock 2022 | Jeep JKU 2017
Mods: MaxxAir 7500S | 2x 100Ah LiFePo4 | Victron MPPT 75/15 | Ultimate Trailer Jack0 -
Awesome. Can you provide photos of the hose hookup under the cabinet. I’m guessing you had to change out the hot/cold hoses nuCamp had. Thank youelbolillo said:Swapped out the standard faucet in our '23 Tab 400. This new faucet provides so much more room for larger items under the faucet and has a nice adjustable stream.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
Hope these photos help.
2018 320S / KIA Sorento 3.5 V6 - 2022 400 Boondock / KIA Telluride 3.8 V6 - Utah0 -
@elbolillo thank you so much for the post and pics. I swapped mine out this weekend. Faucet install was super easy and is sooooo much more functional. I forgot to also order the adapters so I'm awaiting them in the mail today to finish it. I was expecting it to be much more difficult to swap, but that was very simple.2024 T@b 400 BD "Tabba the Hut"
2022 Nissan Pathfinder
Cary, North Carolina0 -
Upgraded mine also due to a review on Amazon stating that they purchased it for a Tab 400. Great fit!2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
