Guys I just purchased a '23 400 that had the Lithium upgraded done immediately after purchase. They added a solar input port close to the shore power input and installed an additional CC for it. It's a Victron 75/10. We currently have it opened up for cleaning and inspection so if anyone needs specific photos let me know.
The additional CC was installed just below the fridge on the left side. The original 75/15 is under the bed.
Please send all the detailed photos of the install as you can. I would love to see how it was done.
Great pics. Thank you! Is there no battery disconnect switch in this setup? I don’t see any wires running toward the storage area.
Sorry for the late reply @400Family . Been out of the area for a few days . Was at the NuCamp factory in Ohio yesterday and today actually . Just getting some service and warranty work done .
Anyway , I do not believe the Renogy inverter has the option pull a certain amount of wattage from shore power or batteries at a specific wattage . There is a setting to prioritize the 120 draw from A/C directly , or battery power via the inverter . I just have mine set up as the default to pull directly from the 120v A/C and power evrything when the unit is plugged in , and charge the batteries at the same time. Have the charger amps set at 60amps . (can go as high as 75) . I also still have the factory converter charger as a backup that will charge at 55 amps via a dedicated breaker in the ac /dc panel . Dont use it often , but is available as a backup battery charge source should the Renogy inverter fail .
Yes, there is some wiring involved to power the whole camper via the inverter . This only works provided you have enough battery ah and inverter power . At least 400ah should be fine and 3000w inverter. The inverter has a transfer switch built in and a charger . The 120v input wiring that comes from the camper "plug in " inlet needs to run directly to the input of the inverter , then the output of the inverter will run to the ac/dc converter like how it was plugged into the input of the camper . Essentially , the inverter is just in-between the 120volt inlet and the factory ac/dc converter panel . I also did some wiring to separate the original powered outlets from the 1200w inverter to its own breaker , and have the converter battery charger on its own breaker so I can turn it on or off at will .
One thing that threw me a bit with the Renogy inverter is that there is no 120v pass through voltage when the inverter is not powered up . Not a big deal now that I am used to it . In other words , when the camper is plugged into 120v power nothing will work yet until you "turn on" the inverter . Once the inverter is powered on , it will allow the 120v power "through" the inverter to power up the camper and charge the batteries . Not sure if the Victron Multiplus is like this or not. .
Let me know if you have anymore questions ! Oh , Just an FYI - pretty much all the info and any pictures in this thread are ALL from T@B 400's . The 320 has a lot less battery "area" to work with , so not sure how people are setting the 320's up with batteries and inverters ?
2023 Ford F150 Sport 3.5 Ecoboost 2024 NuCamp T@B 400 BD, Charcoal / White - 900AH LifePO4 , 620W Solar 2016 Ford Transit 350 XLT - Adventure / Travel Van / 320s interior ! 2019 NuCamp T@B 320s Grey / Black - SOLD
Cant beat the price . They are approx $1 . per AH (as of 8/2025). So , right around $900. for 900 AH .
Price has almost tripled since then... LiTime has this offering at only twice the price.
That price was not for the Renogy 300ah batteries (which I believe are almost the exact same thing as the cheaper 300ah batteries) . The $1. per AH I am using are Dumfume brand . They are still pretty close to that $1. per AH price . That said , there are a LOT of these 300ah batteries that are all Chinese and pretty much exact copies of each other (just look at the measurements) . I have approx 1800ah of the dumfume 300ah batteries running in 2 different RV's and they are working pretty great .
Hello I just purchased two Dumfume 12.8v 300ah LifePO4 for our 2021 Tab 400 I will need to expand the wall forward and position them as B0atguy with blocks or an extra wall of sorts. I have the stock Aims power 1200W inverter. As well as the MPPT 75/15 victron smart solar charge controller. We have also purchased the appropriate PD4655V converter replacement compatible for the LiFePO4. I will attempt to install the batteries and also the updated converter. Will call in my son or someone if I’m not able.
my questions: Do I need a smart shunt to monitor? Or will the smart solar charge controller work? Do I need an additional fuse for overcurrent protection? It does seems like the mppt smart solar has low voltage disconnect protection. The inverter also has a fuse.
Does anyone know or have any suggestions or input please?
A smart shunt is always useful for battery monitoring. If you really plan to use up a large amount of those 600 amp hours of battery with items that can run off a larger inverter, then, yes, it would practically be required. Trying to estimate voltage of a lithium battery is possible, but is more art than science. The shunt is a much better device for monitoring.
Your "batteries" is where the low voltage protection would be located. Find your battery brochure and look for the value called "low voltage cutoff". That is the point where the batteries will shut down and not allow any further discharge. The shunt or controller might have some "alarms" to alert you, but I would have to look that up.
In your trailer there is a "Gloso" battery circuit breaker, rated at 40 amps. That appeared to be adequate for the 125 amp hours available in the original battery setup for a 2021 400. In the newer trailers with the larger 400 amp hour lithium battery setups (and I think even in the 200 amp hour lithium setups) NuCamp moved that circuit breaker up to a 50 amp device. Your 600 amp hours of battery would seem to need even more than a 50 amp breaker, but that sort of electrical knowledge is well above my skill level! Someone in the group will know these things.
If you plan a larger inverter, you would also need to sort out the appropriate wire gauge to handle that additional load.
There are a couple of threads about installing the Progressive converter. This is a nice thread, but the owner's trailer was a 2004.
https://drprepare.com/products/12v-300ah-lifepo4-lithium-battery-compact-size-10-year-warranty
For anyone who is interested in purchasing lithium batteries .........this is a GREAT tool to help find the best prices . Customizable for different ah too .
https://batteryfinder.net/index.php?volts=12&capacity=3&multi=1
my questions:
