It only took me 20 minutes to install my Lagun table platform and hardware (minus the tabletop that I'm not done with).
The box includes a photo with instructions. It's easy to follow.
Mark the center of the rear dinnette face panel. I also measured and marked the center of the bracket.
Be sure to keep the top of the bracket at the same height as the top of the dinette panel. Mark your holes.
Drill your holes. Be sure to pay attention to the lower right hole. It gets a 3/4" screw, not a 2" hole because of the Alde being behind it.  Install the screws.
Slide your table hardware down through your bracket and tighten using the black handle at the height you choose. Put the horizontal table top support on the table upright. Use the 3 black handles to tighten as needed.
The table top support is just under 8"x12". The headlamp is being used as a size reference.
This is the upright table support.
Slide your table around as you want.  Attach your table top and enjoy.
Centering on back won't work for the way I use the inside of the T@B. Mounted to the drivers side bench would be better - Think that's possible?
I wanted mine on the driver's side, too, but I have my microwave next to the bathroom wall. I may still order an extra bracket to see if I can rearrange the driver's side to install the hardware there.
OK, I had an outside outlet installed which required a splice box on the inside of the driver's side storage. This is in the way of me putting a 2x4 structure to support the Lagun support bracket. Plus, the wheel well is in the way, too. I'll think more about it.
South Carolina
My table top will be made out of cherry (a good contrast against the birch interior). Mine will be approximately half the size of the original table, give or take some. I'm toying with having a larger table top that will clamp over the smaller table top, but I may not get that done in the next 4 weeks.
I have several questions for you.
Do you plan to use the table top as the bed platform too? I didn't see any cleats on the bench sides.
On the rear bench seats, both cushions have plywood bottoms. Does the table support (pole) fit OK between the crack in the plywood bottoms as well as the cushions?
Thanks
I did have to wiggle the bottom cushions apart to get the post to fit between the cushions. I couldn't feel any deep crevices left by this adjustment.
Thanks again John
South Carolina
We had a table top made up the size of the original table but 6" shorter, so we still use it as a bed support, with one 6" slat board. The table is made up with 3/4 plywood, laminated with a light maple, Formica laminate, covering the top, sides and bottom.
I will be mounting this to the new Lagun table support, from the original table legs.
Just, waiting on delivery of the Lagun.
South Carolina
I am thinking I might be able to mount it between the radiator and the converter, above the surge protector display.
Here's my driver's side. I couldn't get it to load awhile ago. There is now an electrical splice box between the converter and the GFI outlet. The CO detector is on the shower side of the GFI outlet.
Jenn, as I told PXLated above here, I think there should be a 2x4 mounting system for the table pedestal. While I'm sure others will disagree, I prefer to build and attach the table pedestal once and to not be injured because I took a shortcut.
