Here is a link to an article I read. Not being electrically inclined I wonder if any one has any experience with this  and would it be a good thing to do even if you generator powers the TT. We have a Honda 200i that we plan to use.
http://www.noshockzone.org/generator-ground-neutral-bonding/ Many thanks for your advice or comments
South Carolina
0 ·
Yes, I found that our Progressive surge protector wouldn't work unless I provided that G-N bond, when using our home backup generator with the Tab.
That little adapter is how I fixed it.
It's my understanding that the generator will still work with the RV once the power 'guard' is removed from the system (like my Progressive surge protector), but I don't think that it's as safe with no bonding. I think electrical code requirements specify that the two should be bonded.
Also, some generators come with a bonding strap that can be connected, in which case the adapter isn't needed. I'm surprised the Honda isn't that way.
South Carolina
But then it's nice to be able to tell the DW how much money I "saved" by tinkering with this or that for an hour or whatever.
South Carolina
More likely on wine for DW.
Better return on investment.
Happy Trails Y'all
Happy Trails Y'all
You can, of course, test all this out. Place an energy management device, such as the one from Progressive Industries, between the generator and the trailer and see if it will supply power to the trailer. Soon as weather allows (maybe tomorrow), I'm going to try this out. I'll run the generator with the Progressive Industries device attached, then run it without the device just to see what happens.
Happy Trails Y'all
The picture is correct though, and please don't try it wired the other way. Sparks, fuses, breakers, potential fire. Not good.
I seem to remember you have a Honda generator. What size and how do you use it? Our local Honda dealer is having a sale on them and I'm considering a EU1000I just to recharge the battery when it's too cloudy for the Zamp. Maybe recharge the IT stuff.
If you consider a small generator, I'd recommend a magnetic dip stick. It'll pull out any potential metal shavings that may have been left behind in manufacturing. The oil fill is awkward too and you can also buy an extender thingie that makes your life easier when adding or changing the oil (http://www.amazon.com/gp/product/B00O7AB2BA?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s01). Since I have the 2000ia, the link goes to one that fits the Honda 2000W model.
PS I also like the camo-colored cover lol.
Happy Trails Y'all
The exception to leaving the gen in the truck is if I'm going to be in one spot for a week and do a full setup, I'll haul it out even if I might not need it. In general, I live off solar 90% of the time.
1) Just started the generator with nothing connected. I plugged a socket tester into one of the outlets and got a reading of Open Ground.
2) With generator running, I plugged the N-G bonded plug into one of the sockets and got a reading of no error.
3) I connected the Progressive Industries energy management device to the generator without the N-G bond, not connected to the trailer, and got a reading of Open Ground.
4) I next plugged in the N-G bond plug with the PI device plugged in and generator running and got no errors.
5) I then connected the generator to the T@B with the PI device plugged in but without the N-G bond plug and got an error of Open Ground.
6) With the generator connected to the T@B through the PI device and the N-G plug inserted, I got no errors. This was true with or without any load running in the trailer.
7) Finally, and this is the important part, without the N-G plug in the generator while the PI device was connected, it would not supply power to the T@B.
The N-G plug appears to be the easiest and best way to use a generator with an energy management device between it and the T@B. I read on another forum that you might be able to dismantle the generator and jumper the terminals from inside, but I wouldn't dream of attempting that. It would probably void the warranty, might not work, and could be dangerous.
Happy Trails Y'all
I did find a way to overload the 2000ia Honda by turning on a 1500W ceramic heater (max output 1650W). With the phantom power, the lights (it was getting dark out), the Alde on 2 lightning bolts and the generator being a 20amp and not 30amp service reached it's max. I'll save that little heater (it's a cute one) for later and find a smaller or economical one for the toes - although ThinkGeek has Yeti slippers you can plug into usb ports that warm your toes!!
One thing that I was banging my head on was why I would have 110V with genny and then suddenly NOT. Always had it on shore power. Seemed less power from genny than a 20amp extension cord from inside the basement. Well, the answer was simple when I looked down, exasperated and giving the Honda dirty looks..... The beautiful G-N plug I made for myself had wiggled its way out of the generator socket. Ugh. BTW, there IS a screw where one could put a solid wire ground and tap that into the ground (provided you aren't camping on granite or most BLM lands). That would negate the use of the G-C plug (and wiggling plugs! - who knew?).
I have learned SO MUCH from you all. I can't express my gratitude to you all. Your experiences and trials and tribulations (and Verna's instructional seminars at Coyote) have been so invaluable. Thank you all.
BTW, anyone who has a memory foam topper that doesn't roll up nicely will find getting to fuses a wee difficult. I need a better system! It's on the "roundtoit" List
(http://www.amazon.com/CafePress-Round-Tuit-Button-Magnet/dp/B00PGDBT9M/ref=pd_sim_236_1?ie=UTF8&dpID=51X7LSGHOCL&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=0FK0FV98WPF47EVEWFW2) in case anyone needs a reminder that there's a Roundtoit List that exists in their life.
Hugs and thank you all!!
Patricia
Patricia, in the blog I was reading about the G-N plug (the one that is referenced in the first post of this thread), there is an exchange between the author of the article and a reader about the ground rod you mention. Now, I'm not a scientist, mad or otherwise, and have to depend mostly on others' knowledge, especially when it comes to things electrical. Here is an edited version of that exchange, which indicates you will still need the G-N plug.
I just read your article about creating plug for Ground-Neutral bonding. My generator has a floating neutral also, and the manual shows that… “Before connecting any loads, ground the generator with a length of heavy cable, connecting the generator’s grounding terminal to an external ground source”. They show a picture of the cable running to a metal stake pushed into the soil. However, if I use my receptacle tester, with the generator running, and grounded as they describe, with no other loads attached, the tester reports “Open Ground”. If I plug in the cord from the trailer and test with the tester, I again get “Open Ground”.
Reply:
They’re confusing earth ground with bonding. Portable generators for RVs are NOT required to have an earth ground rod at all by the NEC (National Electrical Code). A ground rod IS NOT the same thing as a neutral-ground bond, which is why you’re still showing an open ground even after hooking to a ground rod. So you should be able to build my G-N bonding plug, and create your single-point G-N bond, which is EXACTLY what the NEC requires. The information they have in their user’s manual is simply incorrect for use with an RV or any sort of home emergency power situation.
BTW, I love that you ran your own tests. It's the only way to be sure. Hope you guys are having fun in the desert. Wish I were still there.
Happy Trails Y'all
