As in undercarriage - Ervery so often when I'm staying in one place for a bit I'll get down and crawl around underneith the T@B and see if anything is amiss. In the past I've found the brake wiring going across from one wheel to the other lose and hanging down. Another time discovered my fresh water drain valve handle (have had that twice). This time I found a big hole in the junction box - Must have gotten hit by a rock...
You can see the hole in the upper right. Lts of dust, sand and rocks in there.
J.D. & Sue
'taint waterproof, till the water tries to get out of it!
Galvanic corrosion is always an issue.
When I installed my alluminum storage box I used rubber strips between the frame along and bottom of diamond plate box to prevent this from occuring. I did use stainless steel hardware. Along with any and all electrical work I've done is crimped with heat shrink terminals.
I edited my post for the mistake or missing conception of a few.
Central,Fl
2015 T@B Max-S
Also should use stainless steel bolts for anything aluminum, for the same reason...
Central,Fl
2015 T@B Max-S
A painter friend likes to say, caulk it to stop water ingress, but not water egress...
Happy Trails Y'all
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
1) There's a silver colored crossbar under the propane cover frame. There's a strap attached to it that holds up the gray water valve. That bar is held in place by two screws - both are missing on mine.
2) My 7-pin connector frame is screwed into the bottom side of my bumper (2 sheet metal screws). One is missing, the other loose.
South Carolina
Used a 2 part product T-Rex liner very easy to work with goes on easy can be done with you're average compressor.
Central,Fl
2015 T@B Max-S
Central,Fl
2015 T@B Max-S
Can someone let me know if the under belly of the trailer is covered and list what year your trailer is?
This is a shot of Pop_T@B (Shawn's) trailer as shown in his posting.
