Post up some shots of your T@B set-up at the camp site!
1151618202149
  • source3source3 Member Posts: 144
    Ratkity said:
    Oh, and many thanks to the anonymous camper with the proper tow strap and tug out of the mud pit.
    If you get stuck again two tricks:
    1. Lower the tire pressure of the TV.  You can go down to 15 to 20 PSI with no issues without trailer.  Trailer attached you may want to keep the tires at 23 psi or so.  Be sure you have a way to inflate tires afterward.  I carry CO2.  More for inflating after offroading.
    2.  Use both feet to control brake and accelerator pedal.  The brake pedal is to stop the spinning wheel.  Keep your RPM around 1800 to 2000 while applying and releasing the brake pedal slowly, and repeat.  Every situation and vehicle is different but with some practice you will most likely be able to inch your way out of being stuck.  The method is called the "poor mans locker".  Some trucks have a limited slip differential.  The above method can still help.
    Andrew P.
    Durango, CO
    2015 S Outback
    The truck could get out fine using the rocking method. It just couldn't get out of the swamp with the camper hitched up. The site had a slight upward angle to the paved road (hard to see in picture). The camper had sunk into the swamp (tires where board is floating). I must say, the 4x4L mode on the truck disables the skid-traction control module and was a nice feature. That said, I thought about lowering the tire pressure like my Dad does on the beach with his 4 Runner, but was hesitant since my tires are the stock hybrid road/all-terrain thingies that come standard on a new truck. 'No tread, no traction' was what I was thinking - rem this was pre-coffee. BTW, I never unhitched when I originally parked, so didn't put down stabilizers or jack. I can't imagine the depth the Lego blocks would have sunk down to! Talk about goo! I was ankle-deep in it.
    It rained again last night and I'm still on relatively dry land this morning (yay!). I did take a picture early this morning of the swamp I was in yesterday morning..... you can see a board I tried to use floating in the water in one pict lol. I returned it to its owner (permanent resident of the campground next door).
    Mud Pit Overview aka The Swamp after another night of rain. Twas a completely under water the morning before:
    Innocent-looking Mudmonsters at new campsite:
    Tire Evidence - even after sprayed down and a night of additional rain:
    I hate mud!  So glad you got out with no damages.
    PXLated said:
    Wow, that looks nasty.
    I don't think I mentioned it, but the bottom third of gray water outlet cover looked like it plowed through the water and muck a little bit. I was surprised the cap strap was still attached to the cap and outlet. The two sites to the right of The Swamp looked as if some people backed in and may have had a little trouble getting out (ground dwellers - no campers). The street was one way and it's obvious they had to steer down the wrong way to get out of their mini-swamps (like I did).
    Thanks V! I'm glad my pride and patience were the only victims. Things easily patched-up with doublestuff Oreos. I had my Friday the 13th on Thursday the 12th.
    Today I saw S.U.N. It was rumored to exist and it's true! I also found a place to eat that had homemade mashed taters with awesome gravy, pulled pork BBQ and homemade applesauce. Nothing like comfort food and a pending nap in the sun.
    I was 13 on Friday the 13th--I love 'em when they come along!
    New nickname = "Lucky Verna".
  • USWildflowersUSWildflowers Member Posts: 177
    edited May 2016
    Indoor and outdoor kitchen, coffee and O.J. while DW sleeps in. Indian Boundary Campground, Cherokee Nat'l Forest, Monroe County, TN.
    Edit: Someone private messaged me a question about this campground; here is a link to my review of Indian Boundary Campground: http://journal.uswildflowers.com/?p=11376
    It does include some T@b-specific comments...
    Had fun traveling out to Colorado Springs...
    Finally a nice weekend to chill out. At Small Country Campground in Louisa, VA.
    u
    Sterling, VA
    There's a small "country" inside Louisa, VA? - Need a passport? :-)
  • Nerdy1Nerdy1 Member Posts: 60
    At last, got everything back together and took out T@boo for her first trip with our new TV (battery cutoff switch both on the TV and on T@boo, a brand new battery on board and a Prodigy RF brake controller).
    T@BOO - 2016 Outback Max S in New Mexico towed by 2016 Toyota Highlander (soon)
    I love Point Reyes! I haven't been in a long long time. Looks like a great gathering!.
    Check out that nice TV of MMike's and Nerdy! Glad the T@Boo got a trip out.
    I'm home safe back in MD with the Mudmonsters. Furmonsters at home were happy we arrived safely.
    Love all the picts!
    Mancos State Park last Friday/Saturday...
    J.D. & Sue
  • kghartkghart Member Posts: 1
    edited May 2016
    First trip in our "new to us" 2005 Dutchman T@B to Coopers Rock State Forest, West Virginia.
    You are just going to have to come east of the Mississippi to find out.  Great rural area of the Old Dominion.
    Sterling, VA
    kghart - That's a nice, clean looking T@B.
    Cyclonic - But if I need a passport it means I have to plan ahead and you know that ain't gonna happen. I plan once and pretty soon I'll have to get into detailed spreadsheets like a couple people we know :-)
    I know not what you speak of... :smiley:
    Sterling, VA
    I used to live in Delaware (now home in Colorado), and know the four corners of the wonderful state of VA well...I have good friends who retired in Roanoke.  I stay in touch despite the fact they bought a big Airstream ;-)
    J.D. & Sue
  • lara9209lara9209 Member Posts: 45
    Something to aspire to
    John & Lisa, 2016 M@x S, Silver/Yellow, Hood Canal, WA, TV = 2008 Toyota FJ Cruiser
  • MouseketabMouseketab Member Posts: 1,238
    Texas T Campground in Cornersville, TN right off of I-65. Simple overnighter campground. Visiting friends who work-camp there full time.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • JltabJltab Member Posts: 89
    Clingmans Dome, Smokey Mountain NC
    2016 T@B Maxx S, Nissan Pathfinder
    I'm not even close to done yet, I have since added links to the campgrounds, links to campground maps, GPS locations, links to the activities, and nightly costs.  The green highlights are where reservations are already done, the rest will just go unreserved in case I decide to change plans.
    I pass it along to my wife, some friends and the cat sitter so they have a good idea of where I will be at any given time.
    Sterling, VA
    Very nice, thanks for sharing.  Looks like a small camper next door as well.
    Sterling, VA
  • ThunderhavenThunderhaven Member Posts: 4
    edited May 2016
    Quick mid week overnight to Caesar Creek campground (Waynesville, OH)
    Moderator's note: Photo edited for size.
    edited May 2016
    @TerryV6, we all start somewhere.  Most of our camping is at private campgrounds, often not the most lovely of places, but sometimes they are, and often they are very convenient to where we really want to be.
    Yours looks like a really nice site compared to our site two weeks ago.
    Sterling, VA
