hey, outbackaz don,t know a place to get them... (1) 3amp type 3ag---ac circuit... norcold part # 61654622..... (1) 20 amp type 3ag--- dc circuit norcold part # 61440522.... (1) 1 amp type 3ag-- gas circuit norcold part # 618079.... I hope this helps, Manny...2015 L-max
outbackaz... just came back from Camping World.. I have one 3 mins from my house... They had assortenment of those glass fuses.. I have not physical looked at the fuses for the fridge.. but they should work...
Removing the cooktop is VERY easy. Turn off propane at the bottle, remove the Fridge blade fuse from the fuse box on the passenger pedestal, snap off the four plastic bumpers under the glass cover, remove the four screws holding the cooktop to the counter, use a plastic putty knife to break the caulking bead, then lift the cooktop out and over to the sink. Some photos below. Hopefully Photomom can provide a source for spares with the description below.
Pull the Fridge blade fuse (#4 position - see label on cover):
Use a plastic putty knife to break the caulking bead:
Simply lift the cooktop out and place over the sink:
Red arrow points to fuse location. Yellow is the thermocoupling (FYI only):
Arrow shows plastic cover over the 3 fuses:
Fuses with plastic covers removed (1amp fuse already pulled)
@OutbackAZ, did you install the wooden corner blocks into which the stovetop corners screw? Mine (2015-S) had these miserable fussy little clamp-thingies that are supposed to rotate into place and grab the underside of the counter as you tighten the screws. Some did, some didn't, making the whole removal and reinstallation more aggravating than it needed to be. I think I might upgrade to what you have; maybe even install some threaded inserts to catch the screws...
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
Just noticed I pulled the wrong blade fuse. The #4 position relates to the circuit breaker. The fridge is the blade fuse in the #2 position (15 amp). DOH!
2016 Outback 320 2024 Ford F150 Supercrew short bed.
Interesting, Outback-- great pics, BTW. Our '04 Dutchmen T@B has a different stove, but the one in your pics is exactly the same as the one in our 2015 Roadtrek SS Agile. (I actually prefer the older one in our T@B.)
Just to be clear these fuses are 3.2 cm long and .6 cm in diameter or 32mm x 6mm. The heading on the diagram states 32cm x 6cm and that is one big fuse.
2016 T@B M@X S grey/red 16 Foot Airstream, towed by 2014 Jeep Grand Cherokee V6 4x4, Central Connecticut
They look pretty standard to me (32 cm long):
Close up next to a ruler:
OK, just ordered all three fuses from Amazon for $27 including shipping (2 are 5 count packages and one is a 3 count).
BTW, please ignore the dirty cooktop in the photo above. Did not have time to clean it after the last campout!
