What do you consider to be your "Most Valuable" trailer mod?
Not as flashy as a pimped-up poop pipe, but without a doubt my battery cutoff is by far the most valuable. It's not a mod for newer units, but before these were standard equipment the T@B's significant phantom drain killed many a newbie's first battery!
A close second (and also no longer relevant): bed slats...
One of my speakers (passenger side) has started cutting in/out. I've had the T@B just over a year, so the warranty is now over. I am fairly handy with electronics (when I can get access to the component wiring). Just curious how you gained access to the rear of your Jensen stereo? Or access to the rear of the speakers?Ratkity said:The on/off LED switch for the Jensen stereo and fixing a speaker that was cutting in and out at the same time (loose connector next to the Jensen. Adding the spare tire mount (mine got put on the Yakima rack). Heater vents (2015 didn't have those on the back shelf) and finally, the digital Alde panel (now standard).
Marc & Janet
2016 T@B S Max (H@banero) - 2025 GMC Canyon Denali - Magnolia, TX -
@duckblind123 - the speaker covers come off by turning counter clockwise, then two screws to remove the speaker. The Jensen has four screws, one each corner at the front. At least this is how it works for our 2017 Outback.
Sn@pDog, 2017 Outback, Silver w/black trim -
@Dalehelman where did you get those baskets? Did you have to modify them? And how are they attached?2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX
Purchased plastic baskets at Hobby Lobby cut them in half. Mounted per pictures. - Hash T@B Fun
Marc & Janet
SnapDog said:@duckblind123 - the speaker covers come off by turning counter clockwise, then two screws to remove the speaker. The Jensen has four screws, one each corner at the front. At least this is how it works for our 2017 Outback.
Thanks! Speaker cover came off just as you mentioned. I'll plan the wire tracking this next weekend as no trips are scheduled. Thanks again!
Marc & Janet
Pros and cons of drilling a new side a/c exhaust vs enlarging the unused battery fume vent, yes the battery has been removed.
Fruss928 -Bob, do you know what your tongue weight is with that Tongue box addition? It looks/works great but I have a 200lb tongue weight limit. Nice work!rfuss928 said:I think it is the tongue box. The DM clamshell did not come with the plastic propane bottle cover included on other models because of lack of space on the tongue. Careful measurements and selection of available boxes let me add a completely closed container on the front of the trailer.
In this box I carry:
10# and 5# LPG bottles and regulator
BAL Leveler
30A - 30ft electrical cord
30ft hose
4 wheel chocks
4 stabilizer pads
Hitch lock
Power drill and socket extension for stabilizers
Rubber mallet
Misc. electrical adapters
Charcoal lighter
Trailer hitch alignment aids
A few other small items
And it holds my spare tire mount!
I can completely set up and connect when I get to my campsite without ever opening the trailer.
Probably a very close second is the solar panels on the roof. I have had virtually no battery charge issues since the installation and they require no attention. They are always on and maintaining the batteries regardless of when or where we are.
Have fun!
Bob -
rfuss928, those solar panels look wonderful. Can you give us some info about them: price, supplier and if you installed yourself. Thank you.
For me, my most valuable mod is a three way tie:
Bike rack installation
Sewer hose carrier installation
Combining black and gray valves
2017 T@b 320 S
2017 Kia Sorento SXL AWD
@rfuss928 that tongue box is awesome........everything you need for set up right there Great set up!2015 T@B Max CS-S Silver and Black
Goes where it's towed to by 2017 Subaru Outback -
@Dalehelman Can the grey water valve be mounted so that it pulls from the side opposed to pulling it up?Dalehelman said:
Without a doubt.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle. -
Without a doubt.- Hash T@B Fun
The solar panels are UniSolar ePVL-68.Lesley_and_Ian said:rfuss928, those solar panels look wonderful. Can you give us some info about them: price, supplier and if you installed yourself. Thank you.
The company went out of business in 2012
Occasionally some NOS come up for sale.
There is a brief photographic description of the installation on the Yahoo T@B forum:
https://groups.yahoo.com/neo/groups/tabtrailers/photos/albums/2085694046
I added about 80# at the box location including the spare tire compared to the stock steel LPG tank alone. This results in about 50# additional at the hitch ball.Dptrit said:Bob, do you know what your tongue weight is with that Tongue box addition? It looks/works great but I have a 200lb tongue weight limit. Nice work!
Tongue weight is greatly effected by how you load your trailer.
The tongue weight stated for your trailer is measured with the trailer empty, as delivered. It is very unlikely to be the same with full tanks, equipped kitchen and all the rest of your stuff on board.
If your TV is near its limit you should check your tongue weight just before you hook up to head out. Items can be moved forward or back to shift the weight. Generally, 10-20% of the total trailer weight is recommended for towing stability.
Ok, this I need to know.Ratkity said:The on/off LED switch for the Jensen stereo and fixing a speaker that was cutting in and out at the same time (loose connector next to the Jensen. Adding the spare tire mount (mine got put on the Yakima rack). Heater vents (2015 didn't have those on the back shelf) and finally, the digital Alde panel (now standard).
do you kill the complet unit or just the led light? And if only the led light, how did you do it??
this is one of the only negative of our t@g.
thank you in advance!2017 T@G Max Outback "Le Refuge"
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC -
The LED is only on when the unit is on. It turns off when the unit turned off. Turning off the unit also resets the time, but I have a regular clock on the wall. The switch easy to install - just two wires. A regular on/off switch without LED is just fine because you can tell if the unit is off since the lit front is blanked out.
There are 4 screws in the corner. They are the larger square head (name for them escapes me). Figure out where you are to put the switch. Drill hole (size is on switch directions). With the LED switch, you'll tap into the ground wire (labeled on Jensen) and you'll have to cut the power wire (labeled on Jensen), putting male flat connectors on either end of the power line. Make sure you leave enough wire to pull through the switch hole. The switch just pops into the hole you drilled. Careful of the veneer splintering when you drill the hole. I think using painters tape over the area will help prevent it (Verna, is that true?). With a simple switch, you just cut the power wire, add the male connectors to the switch and pop into the switch hole you made. Much easier to install.
Don't forget to screw the Jensen unit back with the 4 screws LOL.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart) -
This is very nice, thinking about changing the box on my T@b outback for a more square type one. But it was my understanding that propane container could not be kept in a close container, more specificaly on a RV.Dptrit said:
BAL Leveler
30ft hose
4 wheel chocks
4 stabilizer pads
Hitch lock
Rubber mallet
Charcoal lighter
Have fun!
Bob
but I could be wrong. Would be worth a little search.
is so. Box could be kept, but with some opening.2017 T@G Max Outback "Le Refuge"
I put a diamond box on my tab and knew the same thing about venting. Propane needed venting as well as the battery. Even though there was a lock for it, it remained unlocked as per regulations. I cut a hole in the back of the box almost as wide as the original bin. I used decorative grating to make sure nothing escaped out the hole on either side. One caveat about putting a big hole in the back of a diamond box with a hydraulic support.... a vertical support needs to be added to the center of the hole. It wasn't a big deal to do it. In the end it looked good
@dsatwork, When @Dalehelman did mine, he mounted the handle for the gray valve pointing towards the front on the trailer. Works great! Best mod yet to date!2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf -
I installed "soffit vents" in an upper and lower corner of the back of the box.Luckyj said:This is very nice, thinking about changing the box on my T@b outback for a more square type one. But it was my understanding that propane container could not be kept in a close container, more specificaly on a RV.
rfuss928, love your map. California has wonderful camping. Hope you can get there some time. We are newbies, 11 nights out and 1500 miles and we love it!!
Thank you for info on your solar panels. Pity they are no longer made, such a good idea. -
Without a doubt.I actually had the gray valve mounted up the first time I did my mod. It was really close to the tub.
The second time I did my mod, I changed it to pull from the front. And like it better.
BTW, I did this twice because I glued before planning ahead. doh!
2017 T@b 320 S
@Luckyj I have AGM batteries inside mine diamond plate box, so I didn't have to worry about venting for the battery. I cut 6 2" holes spaced across the bottom of the tank so the propain has a way to escape. I also drilled a 1/2" hole in the center of the box for drainage. I also drilled a 2" hole in the middle of the back to run the propane hose and battery wires from the cutoff switch to the junction box on the trailer.
Tongue Box Complete with Spare Tire and LowPro Generator locking platform
Fully stocked tongue box
/tongue box with gen mounted and hose storage
Tongue box holes for propane venting holes have protectiveEdge Trim Black Small, 1/8" Fits Edge
Do you have a link to where you got your box?! Very nice!dsatwork said:@Luckyj I have AGM batteries inside mine diamond plate box, so I didn't have to worry about venting for the battery. I cut 6 2" holes spaced across the bottom of the tank so the propain has a way to escape. I also drilled a 1/2" hole in the center of the box for drainage. I also drilled a 2" hole in the middle of the back to run the propane hose and battery wires from the cutoff switch to the junction box on the trailer.
Do you have grommets in the wholes where the wires are running? -
@blackc2004Do you have a link to where you got your box?! Very nice! http://www.homedepot.com/p/Lund-36-in-Aluminum-Flush-Mount-Truck-Tool-Box-9436T/100592776
https://www.amazon.com/gp/product/B00KG9BAY0/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Switch to shut radio completely off when
on battery.
Wiring behind radio. Not much there because I don't have the entertainment center.
Switch spliced in with twist caps.
Push button switch in adjacent cupboard.
Radio on.
Radio off, almost.
Radio off off.
T@B trip wherever
New surprises everyday
See beautiful world -
Doesn't the + and - switches to the left of clock readout adjust the brightness including turning it completely black?Roamey said:Switch to shut radio completely off when
on battery.
Radio on.
Radio off, almost.
Radio off off.- Hash T@B Fun
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
A close second
