I wanted to flush my fresh water tank and I needed to chlorinate my well water so I didn't add any bacteria to the system. After consulting the CLOROX website (see link below), I found a helpful guide to the correct ratios of water to chlorine bleach and an explanation of why such in the case of a natural disaster, it is a helpful thing to know.
I was somewhat surprised that they warn against using the splash-less version of their product for this purpose. I thought it was just a different spout design but it turns out it is a whole different formula with different chemicals in it and therefore should't be used. Also, not so surprising were the scented versions which also should not be used.
Before sanitizing your fresh water system with the recommended 1/2 cup of bleach to a gallon of water, make sure you are using a safe bleach for that purpose.
https://www.clorox.com/dr-laundry/disaster-preparedness-purifying-water/
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
That's 1/4 cup of regular household bleach (5% solution) not concentrate (8.25% solution) which would require 1/3 less (about 2-1/2 tablespoons). Look for % sodium-hypochloric solution on the label.
Steps to Dewinterize Your T@B
1. Mix a bleach solution, “1⁄2 cup per gallon of
water” Flush the system with this solution to
sanitize it.
2. Then flush the system with 2 full tanks of water
to ensure the system is clear of the sanitizing
solution.
Unless you want to be smelling bleach for the next two camping seasons, I suggest you follow the advice posted here!
2014 320S
2016 kia Sorrento SXL V6
2014 320S
tv 2010 Lexus RX350 Matador red
First make sure that any antifreeze is completely rinsed from your system. To sanitize your fresh water tank, add a 1/4 cup of household bleach to a gallon of water and add it to your empty fresh water tank. Fill the tank up the rest of the way, then, using your pump, open up your faucets and shower just enough to fill your lines, then turn off. You should let it work for at least 3 hours, then empty and fill your tank and drain several times until it no longer smells like bleach. Best to do this somewhere that you have full hook ups. We did it at a state campground and it was not fun.
On the other hand, we only washed, did dishes and cooked with the water, we drank jug water which I suspect most of us do here.
Seriously, this is not as simple a question as it appears on the surface. As noted in this thread, many people don't consume the water from their tank. Additionally, minor tummy troubles--especially when traveling--are often difficult to trace back to a single source. Lastly, just because you get away with something ten, one-hundred, or even a thousand times doesn't mean you will get away with it the next time.
Will you die if you don't sanitize your water system? Probably not. Will you get sick? Maybe. Are the likelihood and severity of getting sick big enough to justify the hassle of bleaching and flushing your tank? That's up to you, gamblin' man (or m'am)...
It's a good question, though. Let us know any additional information you uncover, and what you decide to do. (And welcome to the forum!)
Since I empty my tank and I have no low spots, I don't worry about sanitizing it. I will NEVER use bleach to sanitize it and I'm not allergic to bleach either (there are people here that are). There are sanitizing products for RV fresh water tanks that smell decent and are easier to flush out. Bleach seems to be harder to get rinsed out of plastic for some reason.
As your resident microbiologist, I wouldn't go overboard (boat pun) worrying about the fresh water tank. Also, if it's in continuous use for several weeks in a row, there's little possibility that any microbe could have a chance to grow.
Edited to add: Add a one-season disposable water filter before hooking up any water supply or fill ups to the fresh water tank. It'll eliminate sediment from getting into a fresh water tank and it'll remove that sulfur smell that some water campground wells have. Some beach campgrounds have sand that comes out of their spigots. It'll capture that too. The sulfur smell (rotten egg) is HARMLESS, but I'd rather not shower in it and smell like cleanly washed rotten eggs lol.
My system gets flushed with that each fall and rinsed in the spring.
i use a big pinch of dichlor crystals for the first soak and bypass the Alde. Same stuff we use in our hot tub. I found the info on another RV site, where people use like a teaspoon for 100 gallons in their monster RV. A little goess a long way. I tried to calculate the exact amount for our little tanks and it was a tiny amount. When I refill for a trip I put about 10 little grains in the tank, and it has just the faintest chlorine smell. We're on well water, if we were on City water I wouldn't bother.
2022 Ford F350 Tremor | 2022 Cirrus 620
