Hello!
We own a 2016 T@B Max S that we pull with a SUV.
One of the biggest problems we found on our T@B was a lack of storage for the sewer hose.
We solved this by installing a Valtenra 64” E-Z Hose Carrier on the front of the T@B.
The Carrier now stores a Camco – 15ft Rhino Flex Swivel Sewer Kit and Sewer Rinse Cap.
Here are some pictures of the modification.
Some sort of sewer hose storage solution will likely be one of the first mods I explore.
Goes where it's towed to by 2017 Subaru Outback
That is exactly the mod I was wanting to do but couldn't find a good place
https://www.etrailer.com/RV-Plumbing/D-and-W-Inc/PF247703.html
2017 T@b 320 S
2017 Kia Sorento SXL AWD
Hello! I did this modification about a year ago and as I remember, I used the end cap measurement of the holder as a starting point and added extra to allow for the mounting feet on the end of the holder and added for a little clearance on the plastic tub so it could flex. As I recall, I think it worked out to a 5-3/4" or 6" for the diameter of the template. There was enough clearance behind the propane tank and battery but we did have to have to remove the propane hose off the regulator going down below to the main metal pipe because it was short and would be in the way of the new sewer tube. Had a new 28-1/2” propane hose made at a local hose shop. When installing the tube holder, we had to wiggle it through the sides of the plastic tub until the back end cleared the trim on the T@B.
Hello RuthT
Our 2016 Tab Max S did not come with the battery cutoff switch from the factory. I would guess, if there is clearance for the Valterra tube below the battery cutoff switch, maybe you could safely splice additional lengths of the same type/gauge wires to make it work? Sorry , I can't be of more help
Hello SGH0004. I was able to lay everything out and did not have to remove the tub. I did used a Hobbico Hot Knife to slowly melt/cut the tub. As always, use safety & common sense first on any project.
that I don't want sewer hose elbow touching.
