With all the discussions about adding stuff to the tongue, batteries ect., has anyone learned what NuCamp's specs are for allowable tongue weights? Rule of thumb is 10-15% of trailer weight.
My stock tab with full water tank and empty holding tanks was 175 pounds. I thought that this was a bit light for 2000 pound trailer. I have since upgraded to two golf cart batteries and am now at 230 pounds. That is 8.5% to 11.5%. Should be more into the "safe" zone. I am curious as to what the trailer is designed for. Is it 200 pounds or maybe 300 pounds?
0 ·
Switching to dual 6V Batteries in the Tub and using a front frame mount spare tire may (most likely will) require shifting some of the moveable load toward the trailer rear to stay within the recommended tongue weight range.
nuCamp sales literature [SL] and the DOT Label on the trailer frame indirectly tell us the 'trailer design limits' do follow the above Rule of Thumb. Following numbers for 320S standard.
. . . . . SL Tongue weight 140 pounds at tare weight
. . . . . SL GVW at tare 1,788
Therefore (minimum) trailer tongue weight is 7.8% if the trailer is keep level when hitched. But we will never see that light a loading in the real world.
. . . . . SL Tongue weight 200 pounds with Grp-24 Battery and 20# full Propane
. . . . . SL GVW 1,848 at same loading
Therefore trailer tongue weight is 10.8% (round to 11%) if the trailer is keep level when hitched. So as we load the trailer for camping we should place the load so we don't get below 11% . . . . . which is nicely at the low end of the rule of thumb
Since it appears the designers followed "the rule" we can define the maximum safe tongue weight at 15% of DOT GVWR which is 2,800 . . . . . . Tongue maximum weight goes to 420 pounds assuming the trailer itself is fully loaded. But 420 is only a limit, you don't want that when the trailer is running near tare weight.
So we have a variable tongue weight range 11-15% of a varying loaded trailer weight 1,848 up to 2,800. This is why all the articles recommend you have your TV and Trailer weight truck scale measured so you know the real trailer GVW for the equipment you carry and your style of camping. After a few scale station stops you will be confident of your typical Trailer Weight and how you need to adjust the moveable load to achieve an 11-15% tongue weight.
Well that turned out to be a bit lengthy and did not directly answer your question on 'nuCamp design limits' . . . do hope it was still helpful.
It's a moot point though, as you likely wouldn't want to tow a 2000lb trailer with a 600lb tongue. MuttonChops' assessment seems pretty reasonable for real-world applications.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
hope you get that sorted out!
I'll send you a sticker for it.
There was a discussion here not too long ago about the effect of having the trailer off-level on tongue weight. Somebody collected actual data and I was surprised what a difference it can make. Presumably this occurs because tilting the trailer one way or the other shifts the center of gravity over the axle and changes the weight distribution on the wheels vs. the tongue.
Ball Location pounds =
Jack Location pounds * ( Distance Jack to Axle / Distance Ball to Axle )
On my 320 S with Outback Front Rack and Outback Spare Tire at Jack Post the typical difference in the weight is Ball about 30 Pounds higher lower than Jack. Jack measured with ball at towing height, bathroom scale (500# rated) with wood pad to distribute wheel weight.
Distances are estimated from drawing, not measured
When I bought my trailer, they weighed the tongue (at jack tube) at about 100# (with some fresh water, battery and full LP)! That's not even close to specs. A couple weeks later I had them weigh again and same. So assuming that was correct, then 200# seems about right. I don't know what the trailer weighs though, so don't know if I'm in the 10-15% range. But I am glad I moved that spare.
I think this also shows if I want to get the outback platform, I would be ok on weight? Although, all my heavy gear currently sitting on the axle would then be moved (maybe 40#). My car has 5000# tow capacity and 500# hitch capacity.
Thanks for all your help and certainly let me know if this seems totally out of whack.
Huntington LI
Sharon
