Again! Same problem I had last year, exact same piece of trim. The aesthetic plastic trim that covers the corners has cracked completely through. The replacement piece is less than a year old! And unfortunately it will not be fully warranted. I understand that the trailer is over a year old, but the replacement trim is not! NuCamp's response was a bit snarky, even, and nowhere near the rosy customer service experience that I normally read about on these forums. Oh well, it's just a piece of aesthetic plastic according to them.
They did offer to sell me a replacement at cost, though, so I suppose that's something. I don't know what 'cost' is, though, as it was not mentioned in the email.
So... are there any permanent solutions to keeping these plastic pieces from cracking? Or even a solution that doesn't involve yearly replacement?
Also... not sure what category to use. I hope it's in the right spot
I haven't heard many reports of this particular issue, so all I can guess is that maybe the attachment points (screws, I assume...) are a little off on your trailer, torquing or otherwise stressing the plastic a bit once it's tightened down. Over time the stress causes a crack.
I wounder if you reamed out the holes a little on the new part it might give it a little play and maybe relieve the stress enough to prevent the damage. Hardly a perfect solution, but neither is having to purchase and replace a new part every year!
Same piece as last year, just a different spot. I may attempt to fix it, but I'm more tempted just to leave it and let people ask me about it.
Anecdotally, it seems the black trim has been over-represented in cracking issues. I wonder if it is more subject to thermal expansion.
I'm sure that the black plastic is more problematic. It absorbs more heat and thus is prone to larger amounts of expansion. I replaced the trim the first time, and I drilled larger holes to allow for additional expansion, hoping that would cure the problem. It is just a poor design or poor choice of materials on the part of the manufacturer.
I gotta say that I am a little disappointed, but I understand that there is little that NuCamp can do after the fact. I don't expect them to keep sending me free replacements, but a workable solution would be great. The email that I received from them was a bit snarky, which is primarily why I am disappointed.
In any event - I just got the quote back from their parts department. $62.24 for the replacement trim piece. $146.75 ups ground shipping!!! Egads, that's $208.99 to fix a design/material problem with these trailers, and this doesn't even guarantee that it won't happen again. I'm sorry, but this I just cannot agree with.
I don't think many people will be asking about it. Most people would not notice, or assume it's supposed to be in two pieces.
Hey, I get it. It's just a piece of trim. On a $24K trailer, though.
My T@B is still under cover but ColoradoJon's post inspired me to feel around the edges a bit. And sure enough...
Not only is the split not clean and straight, it's actually cracked in three places on the side face. There's a very good chance that a chunk or two will actually fall off in short order.
Knowing the cost to replace this, I'll probably settle for a couple patches of black duct tape. It will make a cute conversation piece on my vintage three-year-old trailer, right? And after all, I only paid $18K for mine...
John
2007 T@B
Rockford, IL
But alas, it is the world we live in.
I'm not looking forward to removing that piece and trying to keep it intact and aligned while I secure it up, but I've fried bigger fish. Any additional tips for patching this from the back are welcome. Given the extent of the cracking, I think a fiberglass band-aid on the back might be the best way to go.
Whatever you do, you may want to consider expansion / contraction due to temperature changes; which is likely the cause of the cracking in the first place.
The crack wasn't there when I parked it and covered it late last fall, so it almost certainly derives from cold-related contraction. I'm interested in seeing what it does when it gets hot. :-/
As with you, nuCamp offered replacements at cost and, while UPS is still expensive because of dimensions, it costs about the same to ship four as it does one.
Des Moines Iowa
2016 S Max Sofitel
I attempted to alleviate the problem by making oversize holes in the trim piece and allowing the trim to sit in the sun to warm up and become flexible. The trim is attached to the trailer by the keder rail screws and cannot be over tightened - it appears they were randomly placed along the trailer wall and most of them do not hit any major support structure and were screwed directly to the panel.
I looked closely at the second broken piece this weekend and it appears to have failed just to the left of a mounting screw, about one inch away. Nice, straight, vertical crack that goes all the way through the trim.
Not that I'm considering this at this point, but I wonder if a "nuclear option" could be to just ditch the trim and go au naturel in the style of the CS T@Bs.
An update - nuCamp is assisting me with a replacement piece, which I am very happy about. I will be replacing the broken piece and I really hope to find a method that works well enough to keep it from happening again. I'm going to try using slots in the plastic trim this time rather than larger holes. This should give it more movement to expand and contract without binding.
I'll gladly consider other suggestions if anyone has any
Foundation builders will often score concrete slabs with a circular saw before troweling the floor smooth. The know the slab is going to crack at predictable intervals--this intentional weak spot ensures that the crack is as "pretty" as it can be.
