As a non-mechanical person I am hoping I get my teminology right--the annual recommended servicing that is recommended for Tab axles is greasing, right? Just squirting some grease in? We don't have to disassemble, repack, and replace the seal annually, do we? The cost of these two things are vastly different.
2015 T@b 320S Maxx Outback, aka "Alie Cat"
TV: 2012 Honda Ridgeline
Alice
Crozet, VA
0 ·
In contrast, I suspect many just ignore it entirely. Outta' sight outta' mind,right? ;-)
I fall in the middle. Having the EZ Lube zerk fitting makes it a snap to top the grease up at the beginning of each season, so thus far that's what I've done. It's not like I've put on a crazy number of miles.
Might have to revisit this, though, as I'm heading into my fourth season...
https://tab-rv.vanillacommunity.com/discussion/5934/bearing-maintenance-on-2016-tab-outback-s-max
https://tab-rv.vanillacommunity.com/discussion/6627/video-how-to-grease-dexter-axels/p1
https://tab-rv.vanillacommunity.com/discussion/3295/wheel-bearing-grease/p1
Alice
Crozet, VA
I would do it or have it done every year regardless of mileage, or at least every two if you do not travel a lot.
A local trailer shop quoted me $150 per axle to re-pack bearings, which I think is decent. After what I went through last Sunday I should have payed it
Alice
Crozet, VA
2015 T@B Max S
It specified from early 2013 production dates and forward have the zerk fittings. So, grease annually or every 20,000 miles - whichever comes first!
Sold 2023 Tab 400
Sold 2018 T@B 320S
If you have a newer camper it probably has the E Z Lube. You can tell by taking off the dust cap and it has E Z Lube on the rubber cover. See the photos below.
If you dont have the E Z Lube system you have to pull out the bearings and manually repack with grease. This is probably better left to a mechanic unless you’ve done it before or have someone to show you how. An auto mechanic can do this, you don’t need to take it to a RV dealer.
Alice
Crozet, VA
Alice
Crozet, VA
This seems like something not worth skimping on. I think there are some under the impression that replacing the seals and I suspecting the bearings is never necessary and that is not my understanding from nuCamp.
I also ask for an annual safety inspection either from my utility trailer place or nuCamp. It's helpful to have another set of eyes looking fro problem areas.
Sold 2023 Tab 400
Sold 2018 T@B 320S
best explanation I’ve been given for the time schedule is that trailers sit more than cars. Sitting allows moisture to build up in the bearings causing rust on bearing surfaces. When next used, the rust shears off and contaminates the grease preventing the oils from doing their job. Enough cycles of this and grease just breaks down. Car bearings get exercised more frequently and dispel moisture, even from just condensation, frequently enough to prevent rust from forming.
Any mechanical engineers out there willing to clarify any of this further?
Another related point copied and pasted from a post last year:
"One more point related to the wheel/axle service should be considered. At the same time that the bearings are checked annually (or @ 12K) the brakes should also be inspected. The EZ Lube makes it possible for almost anyone to lube the bearings, but it does not address the need for regular brake inspection. We should all aspire to doing our own service and learning how to "wrench" is a nice part of the T@B experience.... but if your skillset does not include inspecting brakes you may be better off leaving axle service to your mechanic. The greasing is the easier one of the two...
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
Sold 2023 Tab 400
Sold 2018 T@B 320S
2019 T@B400 Rogue
2012 VW Touareg 3.0 TDI
In hindsight, was there any way to know before failure the bearing/brake work was done badly?
Thank you, very insightful info.
Sold 2023 Tab 400
Sold 2018 T@B 320S
2019 T@B400 Rogue
