Who has at least 1 Dale Helman mod?
jkjenn
Member Posts: 6,423
How many Dale Helman mods do you have?
Dale has contributed so much to improving our T@b experience, I thought it would be fun for Dale to see how manuly of us have his mods at work.
I have the fishing rod flag pole holder, am working on the window guard, and have made arrangements to pick up one of his plates to do the leveling jack mod.
Who has at least 1 Dale Helman mod? 31 votes
2The portable drill tongue jack (my favorite mod) and the single discharge sewer drain.2016 Outback 320
Plumbing vent conversion to allow tank flush! Brilliant!TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
None, yet, but working on it!None yet, but I want to do the single dump mod at some point. If I were closer to Ucamp by 2000 miles we'd be gettin' 'er done!
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
@db_cooper
I am in Spokane. With the name db_cooper you must not be to far away.- Hash T@B Fun
3I voted 3, but then realized I have four:
1. P-trap replacement
2. Rear wire shelf
3. Door strut
4. Drill jack handle replacement
Probably more coming.
Not the first time I've said this, but thanks again, Dale! 👍👏-Brian in Chester, Virginia
I see what you are doing there, trying to flush me out of hiding.😎Dalehelman said:@db_cooper
We are full time wet siders, part time dry siders (Leavenworth). We'll be passing through mid July, maybe I can buy you a cold one. Wait, that's @Ericnliz. 😀2015 Max S Outback | 2010 Xterra -- Retired
4+@Dalehelman you are an amazing mentor and definitely the King of Tab mods! I just used my tank flush mod this afternoon. Works like a charm! I’m usuing the safety pin to keep the pipe insulation piece from disappearing down the tube. Since I know it works I’m going to attach it with silicone on the bottom half, keeping the top flexible for various hose widths. It’s a great backflow preventer!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red -
My 2018 CS-S came with a single dump - so every new T@b owner from last year on thanks you, @Dalehelman.2018 T@B CS-S Towed by 2015 Subaru Outback 2.5i in the wilds of Minnesota
The best part of a new idea. Is seeing how you folks take an idea and put your own spin on it. Sharing is the best part.
- Hash T@B Fun
None, yet, but working on it!We have none yet but should be coming back from ÜCamp 18 with 4. P-trap replacement, single dump valve mod, jack handle mod, and coleman 15' x 15' dome with custom leg extensions so the dome clears the t@b ih height. More to come. I think @Dalehelman is a tenured professor at t@b university. Either that, or he's Nücamp's west coast senior r & d consultant under a non-disclosure agreement. I vote we give him the platinum patch for t@b modification excellence. Just sayin'.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
@dragonsdofly
Sharing Ideas allows me to feel useful as I get older. Thank you- Hash T@B Fun
None, yet, but working on it!@Dalehelman, I only speak the truth. I'm sure many others would agree.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
4+It's gettin' to the point that I have a hard time keepin' track of all @Dalehelman's helpful hints & mods! A HUGE thanks to Dale for all the help & advise you've given to not only myself, but a lot of others as well. I feel very fortunate to have you close enough for "hands-on" help & pointers.
Eric aka: Lone Wolf -
Not really a mod. I use the bed sleeping arrangement, that still allowes 1/2 of the floor space between benches. Thanks Dale!
jeannie2015 T@b S Max white with silver trim. 2018 GC Trailhawk. -
Remember ....this IS. Your plumbing vent, and should not be sealed. Dies that rubber gasket press up against the door?Homebodyatheart said:@Dalehelman you are an amazing mentor and definitely the King of Tab mods! I just used my tank flush mod this afternoon. Works like a charm! I’m usuing the safety pin to keep the pipe insulation piece from disappearing down the tube. Since I know it works I’m going to attach it with silicone on the bottom half, keeping the top flexible for various hose widths. It’s a great backflow preventer!
2018 320S Outback -
My version...what can’t be seen is that I epoxied window screen to the back of the lid to keep vermin & such from going thru the holes I drilled
2018 320S Outback -
None, yet, but working on it!Is there a tutorial on here for the tank flush mod? I can't find one.2015 Max S Outback | 2010 Xterra -- Retired
Search: How I flush my black water tank. Sorry I do not know how to link to it.
- Hash T@B Fun
4+@4ncar I do know it’s a vent for both tanks, and the cover is not sealed or airtight. It’s not a rubber gasket, it’s pipe insulation which is split at the top. It is not flush with the door. It’s also the same hatch recommended by @Dalehelman, reconfigured at my own risk. Thanks for your concern. 😊2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
None, yet, but working on it!Thanks Y'all!
1Dale's window guard, complete!
Very cute and so is your window guard.
Do you plan on securing the ends similar to the way I did?- Hash T@B Fun
Nice job Jenn!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
2First use of my Flag Pole Holder.Works just like mod expert, @Dalehelman, said it would . . . . . .
'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
Yes, but after this trip...I need to cut more off of the metal strips and I ran out of time. The window film was disaster. I will just clean the window before putting the cover on, for now.Dalehelman said:Very cute and so is your window guard.
Do you plan on securing the ends similar to the way I did?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
- 919 Introductions
- 74 Teardrop Groups & Links
