I don't want to drill into my brand new 400 but I do want the ability to see behind me when driving and backing up.
I ordered this wireless system on Amazon:
I want to mount it above the rear window but I don't want to drill. Anyone tried using 3M automotive tape?
I added insult to injury and tried a great rated moveable wireless camera and put it on the back of my all aluminum toy hauler. The signal blanked out as soon as the rear turned away exactly when I needed to know where the rear-end was vs the fence pole. Ugh.
You have a shorter distance and the T@B has less aluminum, so you may be golden. eTrailer told me that I really needed a wired camera when I called tech support (I didn't buy the camera from them, but they are so helpful!).
If i mount it down on the plastic trim piece then it gives me the ability to tap into the running lights and not have wiring all over the place.
I also kind kind of like the idea of a battery and was thinking one of those solar charged power banks so you can set it and forget it.
Huntington LI
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
Also, you could use a mount like a Gopro mount with an adapter that fits your camera.
When end I was comparing he 400 and the LG that was one of the few advantages if he LG as it was pre-wired for a camera.
The license plate is guite high high on the 400 so I may try to mount it there or on the plastic faring. Just need to find or run a hot wire.
Camera arrived today.
They did recommend running the electric off the license plate lights. Not sure how to remove the plastic trim piece to access that whole area though. Anyone with experience doing this?
I removed the rear plastic trim which was held on by screws underneath and body molding tape.
The black wire in the second picture is the camera wire being fed through.
Marked where ore I wanted to mount the camera on the plastic fairing and drilled. Note that the antenna will have to be folded down to open the window.
2018 T@B 400 - "T@KO T@B"
As far as replaceing the tape, I think it will be extremely difficult to remove all of the old stuff and install new. I simply screwed it back down. I did put a dallop of scilicone in that hose that passes through the wall as technically water can enter through there and come in below the window.
In on the highway it is better than nothing as I can see if someone is riding me or if a motorcycle is swerving through traffic and he the signal and refresh is not good. I don’t know if my unit has an issue or if that is just what happens when you buy a cheap camera. I’ll contact the seller and see if they can help.
2016 Jeep Cherokee & 2017 T@B Outback
https://www.amazon.com/gp/aw/d/B01B25HKU4/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8
It's not great, but I needed it before I left on my first trip and that was the only one that would arrive in time. This system does work at highway speeds at both day and night, but it's a bit hard to see the image on the monitor during the day. I ended up making a black hood for the monitor that helped a bit with that.
Wireless reception with this camera and monitor wasn't a problem for me, but the highways that I took weren't that congested.
Nissan Frontier PRO-4X (4.6 liter automatic)
Roof mounted solar panels
https://quickvucams.com/shop/quickvu-digital-product/?gclid=Cj0KCQjwx7zzBRCcARIsABPRscPdIkftuEeHnubRGjTUBN7xfRZGuxR1Q3vjisrUzyDH2OzCzbrKgs8aAojlEALw_wcB
